I`am looking ahead to setting up the fuel system. I want to use the original gas tank to run the (2) Stromburg 97`s from a 2 port fuel block. I opted out of the original fuel pump so want to use an electric fuel pump. What would be the best pump to run this setup? I realize I may need to install a fuel pressure limiter so that I would have between 2 to 4 lbs pressure. I would try and mount the pump on the frame just behind the front body mount. Suggestions?
I’ve seen people run a single with no pump off a stock tank, I doubt two would cause issue. Though I’m sure carb placement could come into place fairly quick. Here’s a bump back to the top to see if anyone has some input
