Hot Rods Please ID this ford transmission
Discussion in 'The Hokey Ass Message Board' started by flatheadfever, Apr 27, 2015.
  1. I am looking for a ford 4 speed overdrive transmission for my flathead. I think I'm looking for a SMOD.
    I have found this out of an 80s f100. What is it?
  2. Looks like a granny-low 4-speed....
  3. NP435. Beast. Yes, granny low. Superstar 4 speed truck for Ford, and Dodge.
  4. No much good for a flathead I guess.
  5. Okay
  6. That's a RUG overdrive; based on the Ford toploader four-speed, plenty strong enough to put behind a flathead. There's also a aluminum-case version known as the SROD that has internal linkage (like a T5) that has the same basic internals but is a bit lighter-duty. Again, strong enough for a flathead. Do check both for wear on the cluster gear shaft/bearings as that's their weak point.
