Please help has anyone done a granada brake swap on a falcon
Discussion in 'The Hokey Ass Message Board' started by galaxie65, May 9, 2012.
  1. galaxie65
    galaxie65
    I have a 64 falcon that i am building for a trip down route 66 so i put granada spindles and brakes on it now i have run into a problem with my tie rod ends the falcons tie rod is to small for the granda spindle and the threads are to big on granada tie rods
  2. Rot 'n Kustom
    Rot 'n Kustom
  3. fortiesfords
    fortiesfords
    from Kansas
    I put the Granada spindle and brake set up on a 65 Mustang and the Granada tie rod ends fit the Mustang tie rods. Maybe you could use Mustang tie rods.
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    Make a shim out of a beer can to space the tie rod end up to size. Caution you MUST use a steel beer can ! :rolleyes:
  5. I did this years ago to a Fairlane but forgot what I did about the tie rods. I think I changed them also to match the Granada rod ends.
  6. FalconMan
    FalconMan
    from Minnesota
    try searching www.tffn.net
    It's been done a million times. I did it on my 63 sprint 'vert and the stock tie rods fit just fine, but it was a V8. If you have a 6 cyl there are solutions.
  7. HRSPWR
    HRSPWR
    from Olympia WA
