Does anyone know where you can buy a GM type Pitman arm 32-4 that is 6-1/4" long and the tie rod end is already tapered. Speedwaymotors sells one #91023401 but the tie rod end is not tapered. You can buy the taper but it cost more than the Pitman Arm. Thanks for any input. Jerry
Buy the arm. Check local shops to see if they'll taper it for you. That's what I did because those things are so pricey. Local shop did it for free. Took a couple minutes while I chatted with him.
I called Speedway motors and they said they had a Universal Pitman Arm that was tapered and would fit the Vega power steering box so I will try it...Thanks ..Jerry
