Technical Picture request: ‘33-‘34 ford radiator splash apron and triangle pan installed
Discussion in 'Traditional Hot Rods' started by Gnater, Sep 22, 2020.
  1. Gnater
    Gnater
    I’ve found the diagram side view but that doesn’t show much detail. Trying figure out what bolts to what in relation to inner fenders, grill, etc.
    Thanks in advance
    Gnater
  2. Jalopy Joker
    Jalopy Joker
  3. AngleDrive
    AngleDrive
    from Florida
  4. Gnater
    Gnater
    Thanks AngleDrive, I actually had his site bookmarked. Great info but no pics of what I need. I believe I have things correct now, or at least as my dad had them when he was putting it together. Got the splash apron and inner fenders bolted together and the grill in. The triangle pan may not work with the current front end it has.
    I appreciate your help!
  5. Johnboy34
    Johnboy34
    from Seattle,Wa
    The triangle pan bolts to the fenders, there are recesses in the bottom of the grill for the bolt heads. There should be D-nuts inside the bottom of the grill and the bolts go in from the fenders up into those d-nuts in grill.
    Sent from my SM-G973U using The H.A.M.B. mobile app
  6. Dago 88
    Dago 88
    Hope this helps. 119940944_654693582133832_5341140797659915627_n.jpg 120088333_258813635308303_4796979516168225727_n.jpg
    Gnater and rod1 like this.
  7. deathrowdave
    deathrowdave
    from NKy
    One of the hardest hod , grill , front sheet metal to align that I have ever touched
  8. Deuce Lover
    Deuce Lover
    On my '33 after the inner panels I installed the fenders then the grille.The inner pan went in last.There are 2 caged nuts on the grille that the pan attaches to.
    Gnater likes this.
  9. Gnater
    Gnater
    Dago 88 likes this.
  10. hemihotrod66
    hemihotrod66
    The pan is bolted to the fenders then the gille has two bolts that go thru the pan to hold the grille in...Like was said there are D-Nuts in the grille for these two bolts....
