Pics of my '62 gasser project
Discussion in 'The Hokey Ass Message Board' started by novas4life, Mar 15, 2009.
  1. novas4life
    novas4life
    from vnc,wa
    Well....................This bad S.O.B. showed up today.
    EFI converted Hilborn 4 port.
    And my motor plate and radiator too.
    Brandon
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Very cool, the dog staring at it cracks me up :). Question about radiator. Is that a 21" and who's the maker.
  3. novas4life
    novas4life
    from vnc,wa
    28" tank end to tank end.Its a Summit (china) brand. ProShop price was
    124.00
    I have the same radiator in my '67.Keeps the car plenty cool running mid 9's on N20.
    I hope it will be enough for the 496. I understand that they make a lot of heat with the huffer.
    Brandon
  4. novas4life
    novas4life
    from vnc,wa
    My vintage Weiand manifold came today. Got it on E-bay. Pretty resonable.Ive seen them go for around 400-500 bucks for the vintage ones. I got it for 275.
    Brandon
  5. OahuEli
    OahuEli
    from Hawaii
    ^^^^^^ Thats a cool looking setup. You said your injector was converted to efi, how did they do that?
  6. breeder
    breeder
    Damn cool build!
  7. novas4life
    novas4life
    from vnc,wa
    The injector bosses are machined for an electronic injector and the fuel rail for them is mounted to the body.
    The aluminum block that you see,would have been where the square barrel valve would have mounted.But instead of a barrel valve,there is a TPS.(Throttle Position sensor).
    I have a buddy that does EFI for high horsepower turbo cars. He is going to help with the F.A.S.T. electronics and programming when I get to that stage.
    Brandon
  8. OahuEli
    OahuEli
    from Hawaii
    Thanks, while I like traditional stuff I can definitely see the advantage of the efi conversion, best of both worlds. Looking forward to a video of the car at the strip.
  9. novas4life
    novas4life
    from vnc,wa
    Took the new parts over to the custom shop today.Just because I had to know if they would fit. I originally cut out the upper notch for a tunnel ram.
    I'll have to widen the knotch about an inch on both sides,but otherwise, it fits well.
    Brandon
  10. novas4life
    novas4life
    from vnc,wa
    Since the car is still at the custom shop. I piddled around a little bit in the shop.
    I "fixed" a bad crack in the Hurst case with some fiberglass,washed it up and gave it a "rattle can resto"
    Then I blew the flanges off the boat headers.Suprised how easily they came off.
    Brandon
  11. treeserv
    treeserv
    from n.j.
    My old leaf springs I used for my wheelie bars and they work good.
  12. novas4life
    novas4life
    from vnc,wa
    Treeserv,Love you yellow II.Great car.
    Do you leave off a transbrake?
    On the hit,once the wheelie bars make contact,does it veer left or right?
    Before I paint the rear axle,I need to decide weather or not to add modern wheelie bars.
    Thanx,
    Brandon
  13. treeserv
    treeserv
    from n.j.
    NO I FOOT BRAKE AND THE CAR STAYS IN LINE BUT I RUN MID 11s. IT LOOKS LIKE YOU WILL BE RUNNING MUCH FASTER THEN THAT. NO ONE WILL SEE THE BRACKETS ON THE REAR, GOOD LUCK.
      5.4 KB
  14. Topper
    Topper
    Nice project. I love the old gassers.
  15. Racrdad
    Racrdad
    Gotta love this pic, looks tuff! Keep up the good work.
  16. retro rodder
    retro rodder
    from cape cod
    cool build keep posting
  17. novas4life
    novas4life
    from vnc,wa
    Brought the car home from the custom shop having the quarters hung and moved.
    Installed the motor plate,and made more clearence in the cowl for the blower.
    Brandon
  18. 63gasser
    63gasser
    You are doing a great job on the Gasser Brandon I am getting some ideas for my Rambler from your build i'm not as good at fab work as you but i'm trying!
  19. jammersspeed
    jammersspeed
    from herman mn.
    car is looking great !
  20. Falcon Gasser
    Falcon Gasser
    That is going to be really cool with the efi conversion. Those Chevy II make great looking gassers. great looking car.
    Jon
  21. superchargedill
    superchargedill
    That is a great looking ride. I can appreciate all of the hard work and lots and lots of hours. I'm building a 64 GTO straight axle car and have a thread going here on the Hamb, but it's no where near the level of your build. Keep up the good work and keep the pictures coming. Dil
  22. dragrcr50
    dragrcr50
    lookin good, we did a blown injected hilborn efi on a 55 , had trouble with the tpi, found out they have it built in italy for them no other will work in its place. and we had to blank off some of the air flow in the hat for it to work off of idle. good luck lookin bad ass
  23. straightaxle65
    straightaxle65
    Don't puss out with the modern wheelie bars. The attached picture is how it should launch no matter who is driving it. :D
  24. Butch M
    Butch M
    way way cool that is going to be one bad ass nova......
  25. novatattoo
    novatattoo
    from Canton,OH
    Yeah I'm diggin it.............
    Later,Bill
  26. Lucky3
    Lucky3
    Very cool and nice craftsmanship !
    She's a beaut !
  27. JimSibley
    JimSibley
    Man, That is a cool build. i am gonna use a lot of this when I do my next gasser.
  28. novas4life
    novas4life
    from vnc,wa
    Guys, It means a lot to me to hear the encouragemnt! Just got back from a work related trip.So hopefully I can make some more progress.
    Thanx,
    Brandon
  29. 65 T-BOLT
    65 T-BOLT
    cool deal Brandon!, keep up the great work, I moved away from the gasser/fx idea...then I go and look at your thread...now its back to the gasser/fx again...Thanks for the inspiration! Jason
  30. novas4life
    novas4life
    from vnc,wa
    Finally had some time to play with the AWB.
    I built the chute anchor,put in frame sub structure for the tin and built the sides of the wheel tubbs. This was my first time playing with a bead roller,so theres a little bit of a learning curve.
    Put in a shot of the battery tray too,I built that a while ago.
    Brandon
