Projects Picked up a minty 35 3 speed trans (corrected sigh*)
Discussion in 'Traditional Hot Rods' started by Boxcar's 1928, Nov 21, 2021.
  1. Boxcar's 1928
    Boxcar's 1928
    20211121_120012.jpg 20211121_120021.jpg 20211121_120738.jpg 20211121_112139.jpg A recent find. Love the chrome swans neck shifter column. Will do some studying on it later...but do have a double detent cover to replace the single with. Hade an old piece of tape marked "good" runs thru the gears good n tight as if rebuilt. Also showed a price of $150. Someone poured tar on top housing to seal up I suspect.
    continentaljohn and Budget36 like this.
  2. rusty valley
    rusty valley
    Looks like a 33-34 rear mount
  3. 48fordnut
    48fordnut
  4. Budget36
    Budget36
    Check out the last few posts in “Building my first roadster in San Francisco “. It mentions differences in the double detent tops. You may already know, thought I’d let you know anyways;)
  5. alchemy
    alchemy
    FYI, you can't just swap a few parts around to use the later top casting. You will need to make sure the forks match the gears/syncros. Also be aware the lever for the later top has a longer bottom tip, so the earlier lever won't fit.
    The tar is actually the original Ford foam seal that fit under the floorboard tin. They melted with heat and oil/fuel chemicals. Common to find on the top of old Ford transmissions.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    did you verify the vin that is stamped on it so you know it is a 39? or remove the shifter to look for brass blocker rings? The serial number is stamped on the flat pad just above the inspection cover on top. what is the number??
  7. tubman
    tubman
    I second what Mark says. What indication do you have that it's a '39 (or good)? Is it possible that the scrawl at the bottom of the tape says "4 Speed"? Not what I would call the best documentation.
  8. Boxcar's 1928
    Boxcar's 1928
    I will report back with more after I open it up.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    what is the stamped number on the pad on top?
    Budget36 and Boxcar's 1928 like this.
  10. banjorear
    banjorear
    Like others mentioned, you need to open this up to know what you got. Rear mount and top are early Ford. I would doubt this gear set is the later, '39-up style since the forks would need to be changed, etc.
    If the other top does indeed have the 81A 3" fork, then you did good getting the package for $150 since the top is worth that.
    Boxcar's 1928 and rusty valley like this.
  11. Boxcar's 1928
    Boxcar's 1928
    That's an old price tag...I bought it for $50.
    seb fontana likes this.
  12. Budget36
    Budget36
    Heck, the chrome shift lever puts you a few bucks ahead anyways!
    Boxcar's 1928 likes this.
  13. banjorear
    banjorear
    Dang. Nice score regardless of what it turns out to be.
  14. 42merc
    42merc
    The slanted shift tower & rear mount points to it being a 33 34 Trans.
    The double detent top needs the front fork measured to in sure a 3" fork, otherwise it's not much help.
    I wonder if the swan shaped shifter is just stuffed into the 33 top ?
    Moriarity likes this.
  15. Boxcar's 1928
    Boxcar's 1928
    20211122_160747.jpg 20211122_161706.jpg 20211122_155524.jpg 20211122_162330.jpg 20211122_162413.jpg 20211122_162427.jpg 20211122_162435.jpg So some good news and bad news... As yall suspected/identified....nope not a 39.
    But luckily I did manage to grab an actual 39 top in addition to this unit...it too has a swan shifter but not chrome...it'sthe double detent one pictured.. So fingers crossed the case design I have may support the bigger gears. The extra top forks do both measure larger that the complete units with the largest measuring 3in. So there's that. Standing by comments.
    Super clean inside no rust in the case...just nasty gear oil. Very slight burr at the back of the tallest gear
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    vin checks out to 1935
  17. Boxcar's 1928
    Boxcar's 1928
    Thanks for the look up.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    panhead_pete and Boxcar's 1928 like this.
  19. Boxcar's 1928
    Boxcar's 1928
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    nope it is a 35 by my guide. 32's were ser #001-203,126. and yours is 1,316,174.
    it is the sequential number of cars built per year, they only made 200,000 32's so 1.3 million can't be 32
    Desoto291Hemi and Boxcar's 1928 like this.
  21. Boxcar's 1928
    Boxcar's 1928
    Ooops, yesser
  22. 42merc
    42merc
    Also being a '35 gets you a swan shifter.
    Boxcar's 1928 and Moriarity like this.
  23. trevorsworth
    trevorsworth
    I love swan shifters. But what the hell is going on with that other one?
  24. Dedsoto
    Dedsoto
    from Australia
    1. Aussie HAMBers
    He must've bent it over to get it in the photo :rolleyes:
  25. Boxcar's 1928
    Boxcar's 1928
    Got some straightening to do there I guess.
  26. alchemy
    alchemy
    Find yourself a common 40-48 side shift transmission. Shop around for one with good internals, opening the case and look for chipped gears. Might even find one for the same price you paid for this one, if you are patient. Then take all those good late internals, with some new bearings, bushings, gaskets, syncros, and springs from Vanpelts, and put it all in your toploader case. The late shifter casting and 3" yoke will fit right on it. Then bolt whatever rear mount you need to work with your planned chassis. Viola.
  27. Boxcar's 1928
    Boxcar's 1928
    I believe I have two...48 or 49s, 3 speed Ford transmissions. I'll check.
  28. banjorear
    banjorear
    If the '49 is out of a car, totally different trans. and the gear sets don't interchange.
    If it's out of truck, then good to go. Truck trans. had a 29 tooth cluster which is a little steep for hot rod.
    48fordnut and Boxcar's 1928 like this.
