Hot Rods Picked up a 1929 Ford Roadster altered with an injected olds motor
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Nov 24, 2021.
  1. Paul
    Paul
    Editor
    F prefix on stamped number on head was used in '61 and '62
    Just Gary, loudbang and Stogy like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    what was the stamped number on the block? or did I miss the ID info somewhere??
    Stogy likes this.
  3. F199036 on the head tab, 573562 casting on the bell
  4. jimmy six
    jimmy six
    With the Owens Cam decal, no Clay Smith but the word Cams and the name missing above the AUTOMOTIVE the car may have had a second life under a different owner. Maybe there is more to find out…
  5. Paul
    Paul
    Editor
    371 and 394 were stamped on heads, cast numbers on block are a bit hard to decipher but if it has a '57-'58 crankshaft then that's more than likely what the block is too.
    loudbang, Stogy and Moriarity like this.
  6. wheeltramp brian
    wheeltramp brian
    No number on the block they were milled off
  7. Paul
    Paul
    Editor
    It was never there
  8. Stogy
    Stogy
    Why is the Hamb the place to be...This!!
    Congrats @wheeltramp brian and thanks for sharing the goods on the Blast from the Past...AND to the Dot connectors Brilliant!!!
  9. The37Kid
    The37Kid
    Great find! That master cylinder is a 1954 Chevy item.
    bchctybob and loudbang like this.
  10. HOTRODNORSKIE
    HOTRODNORSKIE
    I have a 303 with a shit ton of money stuck into it. You have the real deal from back in the day priceless . Fun motors I have a love affair with them.
    loudbang and bchctybob like this.
  11. Looks like a great find! I love the early Olds engines. I run a blown 57' Olds 371" in my 34' coupe. Looking at your engine it appears you have Isky rocker arms which I have on a 55' 324" engine in another car. If you need more info on the Olds engine try calling Tony at Ross Racing engines in Niles Ohio
    1940Willys, loudbang and Just Gary like this.
  12. jnaki
    jnaki
    Hello,
    I was amazed that this roadster was near us in the pits and that it was sponsored by Clay Smith Cams, so using my limited artistic skills, I drew what I thought the blue roadster could be from my prospective.
    https://www.jalopyjournal.com/forum/threads/friday-art-show-9-11-20.1205316/#post-13740162
    The quiet days of the pandemic allowed me to draw two similar, but different versions.
    A 671 supercharged Oldsmobile version for the drags and a Potvin front supercharger for Bonneville. (Moon Discs with a more streamlined hood and sheet metal cowl area)
    It just amazes me that such a find existed. Now, it will get some of its glory and coolness back into today’s historic information. My brother would have thoroughly enjoyed this information and that it has survived this long.
    Here is a great record setting post: Gas Altered Roadster Class 1959
    After our 1940 Willys Coupe build, racing and final end, our thoughts were to use the same 292 671 SBC motor and built a similar Altered Roadster. But, at the time of the fire recovery, my brother was putting out plenty of alternative stuff to get his mind off of the incident. Eventually, the roadster and Altered Sedans, plus several station wagons all went on a drawing notebook.
    Jnaki
    Reality took over. We ended up with a 1940 Ford Sedan Delivery, a VW van, the endless surf world, and several desert racing motorcycles as a direction going away from drag racing.
    Continued good luck on the rebuild and future of the historic Altered Roadster. As I continue to read some of the old Drag News papers and check out the old photos, I will be on the lookout for other notifications from that time period of drag racing. still an awesome find!
    winr, deadbeat, catdad49 and 2 others like this.
  13. Fordors
    Fordors
    I’m an idiot, somehow I missed this thread until now. What a great find of such an iconic, notable car.
    Stogy and loudbang like this.
  14. wheeltramp brian
    wheeltramp brian
    Thanks jnaki,as far as the exhaust goes did the car has headers that went under the frame like your drawings or do you remember what it had cuz all I got with the car was the flanges with the pipes cut off
    catdad49, Stogy, jnaki and 1 other person like this.
  15. Roothawg
    Roothawg
    Neatest thing I have seen in a long time.
    NoSurf, Stogy and loudbang like this.
  16. Rocket88NZ
    Rocket88NZ
    Wow! What an awesome find, just shows that. they are still out there. You have the start of a whole lot fun putting the puzzle back together.
  17. wheeltramp brian
    wheeltramp brian
    Yes it's going to be a puzzle. Need to figure out what transmission adapter this thing had and locate a bearing retainer for the Cadillac trans the rest shouldn't be too bad
    catdad49, Stogy and loudbang like this.
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
  19. wow, what a great find!
  20. 1971BB427
    1971BB427
    from Oregon
    Really happy for you! This is one of the neatest finds I've seen here in a very long time! Hope you can bring it back to it's former glory!
    -Brent-, Stogy and loudbang like this.
  21. Eddie
    Eddie
    from Georgia
    No trans. adapter as such needed, use a 1950 Olds. manual shift bell housing, (1950 only). As to bearing retainer, again 50 olds or 38-1953? Cadillac/Lasalle.
    Eddie
  22. check with Don @oil and speed. he may have a 50 housing and the candle stick
    kidcampbell71, Stogy and loudbang like this.
  23. wheeltramp brian
    wheeltramp brian
    Thanks guys I messaged them about the bellhousing. I'm going to talk to the guy that I bought it from and see if I can go back to the house and look around some more see if I can find the bell housing and other parts
  24. Thor1
    Thor1
    Ho...lee...Crap! What an amazing find!:eek:o_O I just saw this thread and am subscribed!
  25. Tim
    Tim
    from KCMO
    Wow. Just … wow dude
  26. wheeltramp brian
    wheeltramp brian
    Well I scored a bellhousing and candlestick from Eddie here on the hamb. He's going to look around and thinks he has the throw out bearing assembly and clutch Fork too. I talked to the guy i got the car from and I'm going to go over this weekend and search around for more stuff ,I think the headers that were on the wall belong to the car from the pics I've seen. The flanges were cut off of them and didn't look right but now looking at the pictures they may be the correct ones. Thanks everybody for the great encouragement and info
  27. banjorear
    banjorear
    Wow. Killer!!!
  28. bushwacker 57
    bushwacker 57
    More on Itow's Automotive 1959 he built engine builder. Ed Pinks first Dragster . Featured finished 1961 Rod and Custom.
    catdad49, loudbang and kidcampbell71 like this.
  29. mgtstumpy
    mgtstumpy
    Bores:
    • 303 - 3.75" (49-53);
    • 324 - 3.875" (54-56);
    • 371 - 4.00" (57-58); and
    • 394 - 4.125"
    Flywheels:
    • Oldsmobile 1949 - 1953 (303) - 145 teeth
    • Oldsmobile 1954 - 1960 (324 + 371) - 176 teeth
    • Oldsmobile 1961 - 1964 (late 371 + 394) - 176 teeth
    303 and 324s are internally balanced, external balancing started with the 371 in 1957. Awesome find with providence
    AHotRod, 40FORDPU, Hamtown Al and 5 others like this.
  30. AHotRod
    AHotRod
    I love Hot Rod History
    Lil32, loudbang and mgtstumpy like this.
