Have purchased a So Cal steering stabilizer and cannot read the instructions due to lousy print,would appreciate a pic if anyone has one.Preferably on a dropped I Beam setup.Thanks.
No pics. Mine is mounted behind my axle. I drilled the centre of the axle and mounted one end and clamped the other end to the tie rod. No hard and fast rules other than keep it as horizontal as possible and as close to parallel to the tie rod as possible. Pull the plunger all the way out and measure the travel. Mark the mid-travel point with a sharpie. Push the plunger back in to your mark and bolt it up. Pete
I will be at my shop in a little while and will take some pictures of the ones we have installed on 3 of our cars. Some people mount them with the skinny part of the shock going to the hairpin, but we mounted ours with the fat part going to the hairpins. 6 of one, half dozen of the other........it makes no difference functionally. You are going to love the end result when you get it on there. Don
Hey Don would definitely appreciate that.That was another question I had as to which end where,or does it matter. Thanks Roger
Roger, I went to the shop and took pictures under my 27 and my Son's rpu for you and I was shocked to see that I have been saying all along the wrong way we mounted them. I thought we mounted them with the fat body part on the hairpins, but we actually mounted them with the body on the tie rod instead. It makes no difference in function, but I guess our reason for doing it that way was so less of the stabilizer would be showing. Old age is a bear, my memory isn't worth a damn anymore ! Anyway, here is the one on my 27. And here is the one on my Son's rpu. My other Son has one on his T bucket too but he keeps the car in one of those inflatable plastic containers so I can't get near it to take a good picture for you. Don
What are the clamps off of ?? I have 7/8" tie rod and radius rods and cant find a clamp to fit I even bought a bike seat clamp.
They supply two clamps with the SoCal stabilizer, one for the hairpin and one for the tie rod. Sometimes you have to open it up a bit, but they fit most applications. Don
