I have seen pictures and even Summit listed this fuel pump for tight spaces. I must admit I am curious. Has anyone run one of these and would it work for a stack injector set up. It would sure simplify things. I figure I could still use the same pill set up and everything it would just be so simple. Appears that there is a supply problem even with Summit. I may be late to the party so let me know any and all information that you have. thanks
You may want to contact these folks for more info. https://www.circletracksupply.com/willy-s-super-bowl-system.html
I doubt it could ever supply a steady stream of fuel with the volume needed for a Hilborn style injector system.
It could be used to pump fuel from the rear mounted fuel cell to a front mounted surge tank, .....so that the regular mechanical injection belt driven pump can feed the injectors off the surge tank......but the mechanical plunger pump you're looking at won't run the injection directly, not enough volume or pressure per pump stroke to supply directly to injection..
