I just installed a petronix in my stock distributer and man what a differance. my points went out after about 500 miles and i check the h.a.m.b regarding the petronix and got mixed reviews, mostly good though. And WOW is all i have to say...anyone that was thinking about doing it, DO IT. I feel like the motors got more life....anyways thanks for all the info and help from this site......
The cool part is that it took about 15 mins and when i fired her up i could hear the differance...I also replaced the plugs...but im sold on petronix...
this was one of the first changes I made when I bought the T. I have never had any problems with the unit and the car runs great........score another positive vote
I went with Pertronix on my Buick. Runs great and they're not that expensive....even keep a spare in the trunk just in case. -Lee Atomic Radio www.atomicpinup.com
I smoked the Pertronix in the Merc yesterday after maybe 5 hours of total run time. Quite the mystery...I wired it like all the others I have done and used the Pertronix 6 ohm coil, should have lasted forever, just didn't. I'm sure mine is not the norm as these things usuall work great. -Abone.
I went with a Crane Cam XRi, no problems and I never looked back. Think that's been about 3 years now.
I think Im going to get another one to hold onto as a back up, I will nerver use points again though ..lol
I just put Petronix and their coil in my galaxie and it made a huge difference and you keep the old school look with the distributor.
o yea petronix is great its so easy to hook up and it just fired up first try and help my motor a bunch
I definately agree with all of you guys. I have pertronix on two of my cars and it made a huge difference and I love it. Definately worth the money.
Im sold on it to, Im even taking the duraspark out of the 401 in my jeep because of the fact it works so well, hardly any wiring and if it fails, just plop the points back in and go. Way easy. Brad
my hot rods have the petronix treatment. I swear by it and dont ever want to fuck around with points again (one time I even had a dual point dist. on a street driven car----what a FREAK I was......) ANYWAY........firm believer! Just MAKE SURE to use the coil they recommend.
I smoked one in 2 hours running time, but that's the way with electronics. If you get past the 3 hour mark, you're usually good to go. I kinda wish they'd run the things in first. I have no problem with points, it's just a bitch finding reliable replacement parts these days, that's the aggravation I can do without. Flatman
Fired the '32 almost eight years ago with a Pertronix and haven't set the timing or replaced the plugs since. I pulled a plug about two years ago and it looked like I had just installed them. Like others, when I fired it for the first time I could tell the difference from other ignitions, it just sounded stronger. Frank
I put a petronix in the stock distributer when I was building the rod and i made the mistake of welding on my frame without disconecting the batter and I fried the petronix. I ran points for the first 500 miles and then just put the new petronix in and its a new car....anyways point being dont weld on the car with the petronix hooked up......I learned that the hard way.
I considered the Pertronix for my flatty, but went MSD ready-to-run instead. More $$ but they are bulletproof, I heard too many "my Pertonix burned up" stories here and elsewhere. Big improvement at idle, it never skips a beat, hits on all cylinders every time -- almost eery!
I've had a pertonix in my '51 flathead for about 5 years now. So far so good, and no points to adjust which should really make the debate a non issue as far as I'm concerned. Although I am going to go with an msd rtr Because I've got a different carb on it now and I don't want the vacuum advance. The msd is easier to set a mechanical advance curve with.
I vote yes for the Ignitor, NO! for the coils. 2 failed, leaked oil from the terminals etc. Others on the board here have had the same experience. It's been discussed before regarding the coils, so if anyone's interested a search should turn it up.
for those with failed petronix, they have a great customer service. send it back with a note. I have 2 and they are great. I use the blaster coil. great spark.
