anybody have the recommended location that pete and jakes sbc motor mounts go on a 32 frame. unlike some other parts i've gotten from them, i didnt get any papers with these. thanks Tim these are the ones btw http://www.peteandjakes.com/parts/32/32_motormountsSBC.htm
I dont think there is an exact location to tell you.You need to mock everything up and determine where they have to be. (dont forget to leave yourself room for the dizzy at the firewall)
Doesn't the catalog tell you what to do? Perhaps the directions were on the blister pack, check the garbage it may still be there. Just kidding, Use some logic and determine where it needs to go based on your steering linkage, firewall/distributor and fan/radiator clearance, then tack them in. Don't weld it in utill everything else is plumbed and ready to go.
you should get the instructions , it gives very good dimensions depending on waterpump used , what radiator , etc as already stated , the best is to mock it up i may have them around here , i'll try to scan them
