Technical Permatex #1 to smooth a rough casting
Discussion in 'Traditional Hot Rods' started by James Mundstock, Sep 30, 2020.
  1. James Mundstock
    James Mundstock
    I have a leaky radiator hose on my Flathead. I have tried many methods to stop it. My thought was to put a smooth coating of Permatex #1 and let it harden to smooth the rough casting. Then sand it smooth to creat a better surface to seal. Any feedback will be appreciated.
  2. gearheadbill
    gearheadbill
    Might be a better product to use like Devcon or JB Weld. Both are 2 part epoxy that are sandal. As long as the casting is clean, shouldn't be a problem.
    jimmy six and tb33anda3rd like this.
  3. squirrel
    I'd use JB weld. The gasket sealer probably won't do what you want, but will make the hose stick, and cause problems in the future.
  4. lostone
    lostone
    from kansas
    ^^^ jb weld
    seb fontana likes this.
  5. alchemy
    alchemy
    What's rough? The head or the water pump? I'd actually like them rough a bit so the hose will get some bite and not slip off. The rubber in the hose will conform to the sandcast surface and give a nice grip.
    If you have a deep scratch maybe just fill the groove, but not cover the rest of the surface.
