Really nice F-1 (39) open drive trans. It looks rebuilt inside, No sign of any damage or having lube in it. Mercury gears. I have a closed main shaft and a early clutch lever if older style trans is preferred. --$600 pick up at Pate or RoundUp 34 Model B trans. Excellent shape inside but light rust outside. No damage or rust inside. 32 clutch lever. Has bell and u-joint. The 34 trans parts fit a 32 mount so the trans could easily be used in a 32. Only thing missing is to make an emergency brake mount. ---$300 pick up at Pate or RoundUp 39 shifter. 3" fork and double detent. Tight but out side rusted and some pitting inside.- Shifts great--$150 A bunch of A and 32-4 front springs. All original Ford but some leaves removed from some springs. All good shape. Pick up at RoundUp or Pate.----$75 I can calibrate springs as to deflection and spring rate. I have a test rig and a load cell. I used to make springs. If you know what the weight is, I can tell you how much it will drop. $25 for that service and of course must be done at home. You could buy one at the RoundUp and pick it up at Pate. 40 Front springs. Good stock springs. Great for rear suspensions with narrow axles.--$50 ea. and pick up at Pate ot RoundUp One rear spring 2.25 width. Missing safety leave but in great shape. Came off rear of a 5W 32 ---$50 Pate or RoundUp View attachment 4230344 View attachment 4230346 View attachment 4230347 View attachment 4230350
