"PENETROL" use it , or not.
Discussion in 'The Hokey Ass Message Board' started by FEDSLED, Dec 6, 2004.
  1. FEDSLED
    FEDSLED
    from lynnweed
    How many of you guys have used or tried this stuff, it says it conditions the metal for a better paint adhesion. my question is, we plan on using DP90 on the car,it is in bare metal but has some hard to get to spots where this stuff might help. do you spray the whole car with it first and let it dry then clean it for the paint or mix it with the paint or do you not recomend it at all.
    any thoughts.
    FED
  2. kritz
    kritz
    from flint, mi
    i've used it to add to my one shot while striping, seems to do just fine with that..seemed to make the stripes a little more durable and doesn't seem to have any negative effects on dry time or anything.
    as far as mixing with paint, or using as a pre- paint prep, i have no ideas...some of the painters on here might know...might want to pm mikeo about it...
  3. ResedaCoupe
    ResedaCoupe
    FED,
    I used penetrol (white quart can?) when working on wooden boats, and oil based paints.
    I would not use it with the DP primer. If you are using the DP90LF or the DP90(with lead) I would spend the time prepping the sheetmetal. I used the old PPG DP alot and it will stick to anything. I don't think the penetrol would help the DP cure, which is one of DPs weak points. It likes warmth for many hours to really cure.
    There are some metal conditioners out there, I use them if I have a large area or many pieces. These are different the cleaner you used just before you spray. Check with your paint supplier, most are water based, some swear by em and some swear at em.
    To reach difficult areas you could adjust you fan pattern or use a jamb gun.
    Most painters become master chemists who have no use for directions, soon you too can do this.
    One of my paint reps said - Try it our way first, then try it your way.
    I used the PPG stuff in garage air dry situations. Feel free to PM me.
    Hope it Helps
    Steve
  4. Penetrol is a product made by the Flood co.,,,,it is used as an additive in oil based paints,,,I have sold it for years as a product targeted at home and industrial use.
    Penetrol,,,also used stright out of the can will make a old faded out fiberglass boat look like brand new,,, [​IMG]HRP
  5. FEDER
    FEDER
  6. whizzerick
    whizzerick
    Fedsled, for outstanding adhesion I would recommend starting with an Etching Primer (I use Sherwin Williams GBP980). It is a reactive (phosphating) base that actually 'bites' (etches) into the metal and will greatly promote adhesion of the primer. All major companies have etching primers as part of their systems.
    When I need to coat hard-to-reach areas,I will usually crank the air pressure, lower material output and spray in the recesses.
    In my humble opinion, it is a mandatory step for proper protection of sheetmetal.
    Just my 2 cents.
    whizzerick
  7. DrJ
    DrJ
    I have used Penetrol in the past as a flow agent in the brushed-on varnish on the bed of my truck (an annual ritual, since the blue truck IS my daily driver and sits out all the time) and had good results with it, don't over do it though) but lately I have switched to a same-brand brushing agent as the varnish brand since the low voc formulas available now are so persnickity about formulas.
    Actually, I havent found a good easy flow shiny varnish available in about 6 years.
    They all fight the brush and dont shine worth a damn.
    Did I ever say I hate governments?
  8. Penetrol is better suited for Alkyd Enamels,like 1-Shot.
    I doubt very much it would help under modern Automotive finishes.
    The chemestry is entirely different.
  9. I agree with Rick; when starting with large areas of bare metal, I always use a self-etching primer. I also like the S-W stuff, but can't get it here, so I use the Martin Senour equivalent.
  10. FEDSLED
    FEDSLED
    from lynnweed
    Thanks for all the input guys.
    FED
  11. grumpyredtruck
    grumpyredtruck
    Can one use One Shot to paint the whole car with?
  12. philly the greek
    philly the greek
    from so . cal.
    Why , with all of the various brands and types of automotive specific paints available to everyone (along with the technical help available)
    would you even think about using a sign painting enamel to paint a car ?
  13. 5window
    5window
    That would be an awful lot of little tiny cans, too. :)
