Looking for a peep mirror for my shoebox with a carson top....All the ones i have seen are for either door edge mounted or gutter edge mount . Do they make them to be mounted directly to a door or post?
These bolt directly to the door frame. They are available both left and right. http://www.classicparts.com/1955-59-Peep-Mirror-Original-Type-Left/productinfo/58-513/#.VZQI-RtViko
Don't expect to see much...I'll sell you my clamp on so you can try it for size before you drill holes...
with many clamp on style mirrors can remove section with clamp , then mount mirror by drilling thu door edge for a direct bolt on (screw on). if you shop around you will find ones for passenger side with a little longer arm to have a better rear view - if you do not find them elsewhere search for peep mirrors at amazon.com
The little short ones work ok on the drivers side, suck out loud on the passenger. I look at my right rear fender if I crane my neck.
So-Cal sells a nice swan neck mirror that bolts directly to the door.... http://www.est1946.com/index.aspx/ImageGallery/Index?productId=124 I replaced the clamp on peep mirrors on the '35 with these. My dentist uses a bigger mirror than those damn peep mirrors.
