Projects Parts pile speedster build
Discussion in 'Traditional Hot Rods' started by lahti35, Dec 1, 2013.
  1. lahti35
    lahti35
    A little recap for those that missed the opening post over at the TD&H forum...
    Got this rotten '27 Buick held together with wire for a good price...
      325.1 KB
      274.6 KB
      250.7 KB
    kiwijeff likes this.
  2. lahti35
    lahti35
    A little sketch of what i'm shooting for and a book pic that gave me the idea years ago...
      121.3 KB
      182.4 KB
  3. ThomasT
    ThomasT
    That will be a great looking "ole" Speedster.
  4. lahti35
    lahti35
    Spent last weekend removing 15 gallons of animal bones and waste, stripping it down and selling off parts I don't need. The body will only be as wide as the frame at most so all those brake rods and big springs will be out in the open to see. It's even got brakes up front so thats going to rock running exposed.
      317.1 KB
      307.7 KB
      327.8 KB
    kiwijeff and Felipe Toltecatl like this.
  5. Dyce
    Dyce
    That's a neat setup on the rear suspension. Front looks good too. Looks like you have a good start!!!!
  6. lahti35
    lahti35
    Thats what I thought... I like how they put the axle at the rear of the spring, high cool factor!
  7. Dyce
    Dyce
    You need to search for some lever shocks though. Looks like you could have a lot of roll in the rear. It would be hard to put a sway bar on the rear to look right but shocks help.
  8. GM used Lovejoy lever shocks, and they show up on E--y from time to time.
  9. Mr48chev
    I'm in for the longhaul on this one. Good to see another one of the "old race car" look speedsters going together. You can probably find some photos of Buick based Indy cars from that time period for ideas.
  10. Looks pretty cool. What model buick is it? Some are worth some serious coin. You might check if you haven't already.
  11. lahti35
    lahti35
    It was a 27-27 standard sedan, they made 40,000+ that year. Pretty low on the value list, otherwise I wouldn't have gone wild with strip down. I had one eye open waiting for just the right car to pop up... not too nice to cut up but not so bad I couldn't salvage anything to cover the cost of the frame.
  12. The37Kid
    The37Kid
    Nice project! Check out early 1920's Rolls-Royce they used the same rear spring setup, not race cars, but worth a look for details. Bob
  13. am i the only one wanting to know what you are doing with that cool engine? :D and i want to hear it tho...
  14. lahti35
    lahti35
    The engine is outta here... It was missing a few parts but I was surprised how nice it was on the inside when I pulled the head. It would cost $3-4k to rebuild it so i'm not going that route... i'll pop a straight 8 something or other in there instead. The engine is headed to some 20's Buick folks who need the parts.
  15. Atwater Mike
    Atwater Mike
    If you are considering something 'vintage' looking, (but 'serviceable') consider a Pontiac straight eight, '41-'54. Easy switch, and they are FLATHEADS!
    But the same year Buicks would also do...straight eight OHV, will run 200,000 miles.
    Roadmasters had dual carbs...All of them (Pont/Buick) are Cad/LaSalle trans friendly.
    An old timer said the big Buick straight eights would "Pass anything but a gas station!"
  16. If you're not using the engine, I'd be interested in the Generator/Distributor- my casting is cracked!
  17. choptop40
    choptop40
    hey hey , got a 40,000 mile 1941 olds 98 flathead straight eight with hydromatic,,,runs excellent , different for sure.....speedster....speedster....yowza
  18. lahti35
    lahti35
    Thanks choptop, I've got a line on an engine thats close to me so I'm going to look at that soon.
  19. xderelict
    xderelict
    I like single place speedsters. Cool start.
  20. lahti35
    lahti35
    Houston, we have a power plant... '39 Nash dual plug inline eight... can I get a "hell yeah"?
    Headed down state this AM to meet up with a rightious hamber and brought back this old girl. We got her to fire pretty easy after it had been sitting in his garage for a few years. Condition is excellent it's just a little dusty from an extended slumber.
  21. The37Kid
    The37Kid
    NICE DEAL! Someone ran one of these at Bonneville not too long ago. Merry Christmas! Bob [​IMG]
  22. Hackerbilt
    Hackerbilt
    Now that is cool. VERY cool.
  23. Nice start, I like your engine choice. Right now I'm collecting for a 24/28 Buick speedster myself
  24. captainjunk#2
    captainjunk#2
    wow ive never seen one of those engine s , that will make a very cool speedster mill , im digging this build ,
  25. mechanic58
    mechanic58
    That's neat as hell!
  26. lahti35
    lahti35
    I'm going to streamline the engine by placing whatever I can on the firewall... coils, oil filter, etc... I want it to be clean. I'll also repaint it a 1920's olive green with black trim and add some brass/copper to make it pop. Gotta make it look about 15 years younger!
    As far as the exhaust manifold goes i'm thinking 4 straight pipes. There is no true exhaust manifold, its basically 5 ports in the head with plain old exhaust pipe clamped on. I'll weld up 4 pipes off of the main pipe, no problems with heating the intake or having to fabricate flanges.
  27. BuiltFerComfort
    BuiltFerComfort
    I only see 8 plugs, but 16 (+/-) plug wires. How does that work?
    Also if you can make a custom five into one exhaust header it would be quite different and perhaps cool.
  28. lahti35
    lahti35
    The other 8 are under the exhaust manifold, they run though some tubing around to the other side of the block. The rotor in the distributor has two arms at 180 degrees so both plugs in each cylinder are fired at once. Two sets of points and condensers, two coils, 16 plugs and a whole lotta fun!
  29. Okie Pete
    Okie Pete
    Wow that is a cool engine . The generator shaft drives the water pump ?
  30. Jet96
    Jet96
    from WY
    Here's a "hell yeah" for that engine, nice score that's gonna have a great look !
