parts hauler- a little off topic
Discussion in 'The Hokey Ass Message Board' started by SOCALRICK, Jun 14, 2007.
  1. SOCALRICK
    SOCALRICK
    from SO. CAL
    I have a 88 suburban 350 tbi, thats been sitting for a few years. I need a shop truck so I am trying to get her going. Has spark new cables, battery charged. Got it to start today with starting fluid but it will not stay running. What can I do to check the fuel pump and how do I drain the old gas out of the tank(do I have to drop it?). Thanks, I trust the guys on J.J and always here good things about you guys here!
  2. nick_s
    nick_s
    from Ohio
    you can find the relay for the pump and jump the connector with the key on to see if the pump will run. You cann also pull the larger supply line off the back of the tbi or by the fuel filter and run it into a gas can nand see if it fills up. Could be bad pump, but another possibility(on camaro/firebird anyway) is the oil pressure switch that cuts power to the pump if it doesnt see more than Xpsi of oil ressure.
    and yes you have to drop the tank. only way to get fuel out if pump is shot is to siphon nor use a jack to aid you.
  3. pan-dragger
    pan-dragger
    i've got an 87 w/tbi, it will not run unless the fuel filter is super clean.. i'd start there.
  4. funguynstc
    funguynstc
    yea,if its the pump,you have to drop the tank,but it could be just the relay,a clymer manual from autozone or advanced should tell you the location of it.
  5. 29ZZ4FORD
    29ZZ4FORD
    from NWFLA
    The relay is over the a/c box. It should also have a prime connector for the pump near the relay. Pm me for the details if you want.
  6. nick_s
    nick_s
    from Ohio
    You fix it yet?
