Part list " reasonable offers Considered"
Discussion in 'Parts For Sale' started by 19Eddy30, Jun 9, 2018.
  1. 19Eddy30
    19Eddy30
    from VA
    City: Northern Va
    State: Virginia
    Price: In add
    Hi will be listing more of 35 years of parts
    Edelbrock SB Chevy 3x2 intake
    C-357-B
    With threeEdelbrock 94s
    Set up Little over year old ,
    I milled the four center bolts on intake so it can also work on 87-up. $750
    N.O.S Holley Strip Dominator Tunnel Ram for sbc top & bottom carbs set like @ 45deg angle , Holley stop making around mid 1980s. $550
    1980s torker SBS semi polished $70
    1980s torker SBF $65
    Harlen /Sharp SBF 302 roller rockers
    $140
    MSD big cap SBF 302 distributor
    $125
    SBC Performer intake $50
    1980s Holley strip dominator tall intake
    1980s Standard carb $275
    1980s Holley strip dominator medium standard carb $275
    1980s Holley strip dominator short standard carb $275
    BDS BBC Competition Square port intake blower manifolds $400
    Bower 10:71 Magnesium teflon stripped Blower $1,500
    RCD Front off set mag drive
    $700
    Mollary 5 magneto witch coil
    $450
    60s-70s 3 Hillborn 4 hole 6:71 5 inch tall ,
    One was polisd at 1 time (Hillborn was removed )
    3 barrel vale's ,
    2 with shaft & butterflys
    1 with shaft & 2 butterfly's (2 r missing ) NO scoop
    $1,200 for all
    Nos Enderle Barn Door injection 2nd design ,Polished , base Only with shaft $400
    New Enderle Bird gas , with barrel vale ,Tunnel or Blower $1,200
    New Enderle Bug "NO RIBs"
    Gas blower , with Barrel vale
    $800
    Hurst quarter stick power glide
    $170
    New Sbc stainless steel block hugers $50
    1960s Corvette steering wheels
    Plastic rim $350 each
    1967 Corvette 427 30 over 4 bolt
    Block $1,000
    BBC Steel crank 2pice rear seal
    $400
    SBC 383 long block
    Aries pistons
    H beam rods
    Dragonslayer steel crank balanced From early 90s
    Roller cam
    O-ring block
    Dart aluminum heads
    Will need set of valve springs
    $3,800
    1980 Complete 454 $700
    Early 1990s 454 long block $500
    Buick Electra 70or71 long block 455 $500
    1970 Chevelle 12 bolt rear with
    Morose Bruit poi with 4:56 gear
    $800
    New MSD 6 BTM box $200
    Used msd 6 AL box $100
    New Autometer Tac 6854 $200
    Pair of 66-67 Nova / GTO bucket seat , pass seat ok , driver needs seat cover , $400
    Oem Rally wheel caps "Cone"
    $30 each
    Disc cap "Flat" $40 each
    Chevy Vertex mags adjustable collar
    One with external coil $450
    The other $400
  2. 19Eddy30
    19Eddy30
    from VA
  3. 19Eddy30
    19Eddy30
    from VA
  4. 19Eddy30
    19Eddy30
    from VA
  5. 19Eddy30
    19Eddy30
    from VA
  6. 19Eddy30
    19Eddy30
    from VA
  7. 19Eddy30
    19Eddy30
    from VA
  8. 19Eddy30
    19Eddy30
    from VA
