Projects painting the '55 Bird today!!
Discussion in 'Traditional Hot Rods' started by birdman1, Jun 5, 2019.
  1. birdman1
    birdman1
    My son is going to paint my junk T-Bird this morning, been a long time coming. Got the body blocked, looks pretty straight to me. I am using the Duplicolor paint shop laquer
    paint (performance red). i will let you know how this all plays out.
    Squablow likes this.
  2. Blue One
    Blue One
    from Alberta
    Resale Red, waiting to see pictures.
    Spray booth? Or home job?
  3. birdman1
    birdman1
    in my garage, open doors. Bugs are not too bad yet.
  4. Good paint, used that for my floor pans on my Ford. Sprays well.
  5. Blue One
    Blue One
    from Alberta
  6. A Boner
    A Boner
    Patiently waiting for pics.
    Bandit Billy likes this.
  7. Bandit Billy
    Bandit Billy
  8. Black_Sheep
    Black_Sheep
    This thread really needs some pics
  9. BJR
    BJR
    Where are the pictures?
  10. Jalopy Joker
    Jalopy Joker
    on cell phone that fell on to fresh paint & got stuck there
    BJR likes this.
  11. stanlow69
    stanlow69
    It got a little warm today.
  12. birdman1
    birdman1
    alright already! these things take time! we finally got the 3 color coats on, and then 3 clear coats. Duplicolor says to wait 48 hours to wet sand with 1500 or 2000 paper. then buff it. so here are some pictures of the car after the clearcoat. We tied getting the paint and the clear to lay down smooth, but it always was alittle rough, almost like air bubles in the paint. But it will buff out just fine. took 6 quarts of red and 6 quarts of clear. that is a lot of painting to do. But now I can roll the painted chassis in the shop and start making the motor mounts for the 351 cleveland and C4.
  13. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Birdman Please do not take this wrong , but I have been painting cars for over 40 years. Do your self a big favor and flat sand that with 600 grit wet and apply at least 3 more coats of clear and apply wetter and slower . you will not be able to wet sand and buff that much peal with only 3 coats. Again not trying to be an ass just talking from years of experience. And I am not talking about show verse driver . I am talking buffing through and durability. Larry
  14. X2 what One Bad 51 Merc said
  15. Bandit Billy
    Bandit Billy
    What does that paint job and my the utterance of my junior year prom date have in common? Too dry!
  16. BJR
    BJR
    X3 sand and re clear, put on much wetter.
  17. s55mercury66
    s55mercury66
    from SW Wyoming
    X4 on the sand and re-clear. That should be a fun Bird!
  18. Tri-power37
    Tri-power37
    I would like to help you . I have been painting cars everyday for 30 yearsand it looks like from the pictures that you are applying the product wrong in some way. Did it look nice and shiny when finished spraying and then haze over and get bumpy or was it hazy and bumpy like this while you were spraying ? I agree you should resand and respray but you need to figure out what went wrong the first time. You used enough materials to get a really nice finish. It is easier to resand and spray than to try and polish out what I see in these pictures. I would recommend re sanding the car with 600 grit minimum to remove all the texture let it sit for a few days to gas off and try and rethink what went wrong.
  19. birdman1
    birdman1
    The paint was rough as it was being applied to the car. we used a DeWalt siphon feed gun. 40# air pressure at the gun. theduplicolor is already mixed in the can and is very thin. I can't paint anymore (COPD), so my son is doing the spraying paint for me. With the proper mask. I tried to explain how to set the gun and I think it was pretty close. i think it was operator error. Do I sand with the 600 until smooth, even if it cuts through the clear and into the paint? after the 600, should I use 15000 or 2000 to get it smoother? thanks for the help, I know my son is very dissappointed, so I would really like to make it look better.
  20. Do you and your son both a favor----Sand with 600, go get sum real paint and clear and redo. Duplicolor is JUNK.
  21. I remember someone spraying duplicolor like this on one of those Spike TV shows...similar results.
  22. Bandit Billy
    Bandit Billy
    Yes. It doesn't matter if you sand through the clear since you are going to re-clear. Of course if you sand through the paint that will require more color.
    No, no finer than that 600 is needed, there will be sanding scratches.
    On Duplicolor, I have never used it so I cant offer any assistance. Nor do I know if you can put another brand clear over their product already on the car. I suggest some research on that one before you spend more money.
    Best of luck, painting a car isn't rocket science but it is a lot of chemistry... and voodoo.
    VANDENPLAS likes this.
  23. birdman1
    birdman1
    well, i went and got some 600 wet or dry. I wet sanded about a 12"x24" spot on the trunklid and wet sanded it , slowly, until the paper started gliding across the paint easily. was much smoother. so I sanded it until it was dead smooth, no ripples. then I put my mask on, put about a pint of clear coat in the gun, and did 2 heavy, wet coats. BINGO! it was smooth and shinny like it should be.
    I think I figured out what we did wrong. The directions on the can said the first coat should be a light tack coat. My son put a very light coat on, and it was very rough and flat looking. he want to sand it off and start over with a wet coat, but I told him the next coats will snooth it out. I was wrong of course. so I think we can get a nice shinny paint job out of it yet by sanding it smooth and laying down some heavy wet clear coats. thanks for seeing my screw-up and for all the help figuring it out. photos to follow
  24. Tri-power37
    Tri-power37
    I think you may be on the right track . I prefer wet sanding - a good trick when wet sanding to remove texture is to have some sort of squeegee to wipe over your freshly sanded surface to check your progress . You want to remove the texture but try not to burn through. It might sound funny but you can think of this failed paint attempt as just a expensive coat of primer! Try not to be in such a hurry to recoat your t-bird- let it harden up really good first. When you wet sand it really opens up the surface for drying -let it sit for a few days paint doesn’t like piling up on itself to quickly. I think it is really cool that your son is helping you, my dad and I would do stuff like this all the time. Sadly he passed in 2011-just tell your son how lucky he is to be spending quality time with his old man!!
    SS327 likes this.
  25. birdman1
    birdman1
    father and son working together. nothing else brings them together more than doing work and seeing the results. that's why my cars don't have to be very perfect. I can look at the T-Bird and see what my kids and grandkids have done together. Thanks for all the good advice
  26. Tri-power37
    Tri-power37
    Congratulations a father or grandfather teaching his kids or grandkids how to roll up thier shirtsleeves and put in a days work and look back at what they have accomplished is sadly becoming a lost teaching. My father in law left my wife a beautiful 58 Edsel they worked on when she was little - it isn’t perfect either . But the memories in that car far exceed what perfection ever could.
