Painted my truck! And took it to LSRU (pics)
Discussion in 'The Hokey Ass Message Board' started by tulfabrication, Apr 12, 2013.
  1. jfrolka
    jfrolka
    Man she looks reallllly low. I like the color a lot and the off white interior, very nice.
    Have you thought about some wheel caps and big whitewalls?
    I have a 48 and cut 3" off the bottoms of the fenders and removed the running boards. The trimmed fenders are 3" off the ground. It has f2 fenders and big whitewalls. Has a radius'd wheel well look. I will post a thread when I get a seat in it and out of the shop.
    Lookin good, whats under the hood??
  2. 4rod
    4rod
    real nice...great stance...
  3. smugglerchief40
    smugglerchief40
    from Derry, NH
    Nice rig. color is spot on, I dig the one shiny "tooth!"
  4. jhaas63
    jhaas63
    That truck is bad ass. That is all.
  5. UNCLECHET
    UNCLECHET
    I dig it man! Super cool truck.
  6. A Rodder
    A Rodder
    Cool, looks great
  7. knoxbrendon
    knoxbrendon
    Very nice you nailed it
  8. I like it. I have a 48 cab and a 51 front clip and was thinking of doing what you did. Very nice.
  9. Rob68
    Rob68
    Oh man! I really like it. Looks great.
  10. toucan
    toucan
    from sc
    love the tooth , now lets flake the roof!
  11. Blades
    Blades
    from Chicago
    That color is perfect. Well done good sir!
  12. Gman0046
    Gman0046
    Looks great. I like the color contrast between the grille and the rest of the truck, stance is killer.
  13. 65PANELRAT
    65PANELRAT
  14. mikesnyhere
    mikesnyhere
    Bad to the bone paint and stance nailed the look ! need to check out that paint . there is a Sherwin Williams near me .
  15. suede shoe
    suede shoe
    Looks great! I don't mind the silver tooth, just think it would look better in the center of the grill.
  16. I've always been the type of guy that likes the look for primer,,,for over 40 years hence the name HOTRODPRIMER,,Knowing the truck is not finished in primer it does have that look!
    Congratulations on making the trip with of minimum of problems. HRP
  17. brandon
    brandon
    .....with your gold tooth display'd:D
  18. DAMN.....your PU looks great!
    I really like the color. I'd like to see it raised up in the rear a few inches, looks like your gas tank is only a few inches off the ground, I hope that won't be a problem?
  19. thats actually not my tank, its a storage compartment i built where i have my toolbox and battery. The rear 1/3 of my bed floor behind my axle open's up almost like a trunk so i can get to it. my gas tank is in it's stock location.
  20. It's different then the pic of my bed floor, but I welded nuts on the inside of my fenders and removed the factory studs from my bedsides. Then just got some round head Allen bolts and fender washers to bolt up the fender from the inside. They look great all installed but the main reason behind all that is so if I were to get a flat tire, I could just unbolt the fender from the inside of the bed in order to get the wheel out. Versus having to lay on the ground and dick with unbolting the fender from the wheel well (stock configuration)
  21. ..that's smart thinkin, but I'd still paint those bolts so they disappear...
  22. Successful long distance trip in your own creation..priceless!
  23. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I know a guy that can throw some stripes on there and finish it off.... New color looks good though
  24. InPrimer
    InPrimer
    as far as the fender bolts, I'm using elevator bolts, they are flat on the box side and can be removed/replaced on the inside of the fenderwell. Mine is almost the same xept its a Flattie w/T 5 trans and for now all shiney raw...
  25. pappatyrone
    pappatyrone
    Great colorado hot rod!
  26. paco
    paco
    from Atlanta
    Just happened to run across this truck ... nicely done.
  27. Clark Kent Esq.
    Clark Kent Esq.
    Trucks looks great. I like toucan's idea of flaking the roof. That trunk idea you have there is awesome, maybe you can give us a run through next tech week?
  28. fnjunk
    fnjunk
    from Australia
    Very nice,she sure is sitting down low.
    I like it a lot .
  29. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    Cool truck and the color is right on!
