Technical paint the inside of a bell housing; yes or no???
Discussion in 'The Hokey Ass Message Board' started by atch, Jan 9, 2022.
  1. atch
    atch
    I've got the outside of my nailhead bellhousing looking pretty spiffy. The inside is now very clean also. Should I paint the inside or rub some oil on it (to prevent rust) and use it as is?
    b-t-w; here's the Super T-10 that will be attached to it:
    LOU WELLS, rbrewer, Deuces and 4 others like this.
  2. desotot
    desotot
    I could use a bellhousing just like that with the cross shaft. What Buicks used those? Do you have the bottom cover as well?
  3. atch
    atch
    Nailhead engines. I'm pretty sure that all of the GS Buicks in the mid 60's used this bell housing. I don't know about earlier ones. I'll be using this one on a 425.
    Sure don't. I'll be looking for one myself.
  4. mgtstumpy
    mgtstumpy
    You'd know that it's been done to your satisfaction if done, however it's not necessary IMHO. I removed this OEM T10 FE unit when it was replaced with an aluminum one with lower cover. I cleaned it, 'a la natural', for sale.
    Deuces, Jeff Norwell and loudbang like this.
  5. Put a fine coat inside,,,,,won’t hurt a thing .
    Tommy
    Deuces and Just Gary like this.
  6. atch
    atch
    Fine coat of paint or fine coat of oil?
  7. MAD MIKE
    MAD MIKE
    from 94577
    Just paint it if you are worried about corrosion.
  8. atch
    atch
    I hadn't even thought of corrosion. This thing's over 50 years old and didn't have a speck of corrosion or rust in it. I'm just more interested in what everyone else has done.
  9. F-ONE
    F-ONE
    from Alabama
    Truthfully fully it would take hundreds of years for it to rust and do any damage. It's whatever makes you feel better.
  10. Sorry Mike,,,,,,paint .
    Tommy
    Deuces and warhorseracing like this.
  11. chevy57dude
    chevy57dude
    A outstanding job like that deserves paint. How about a contrasting color, grey or Ford engine green?
  12. atch
    atch
    There's a thought. I hadn't thought of anything but black.
    That's why I ask questions on here. I don't have much imagination and a lot of you do.
  13. Reidy
    Reidy
    If you do paint it, sign your name in there. That way the next person will know who went to all of the trouble to paint the inside.
    Steve
    clem, Bugguts, kidcampbell71 and 5 others like this.
  14. chevy57dude
    chevy57dude
    Like the O.D. color inside WWII aircraft.
  15. Paint the inside an awesome color, nice idea. If, I someday take my project car back apart, I will follow this advice.
    Maybe a little pin striping inside also? Or, even a small, decal. :D That will give the next owner something to talk about.
  16. spanners
    spanners
    Rear main seal will leave a coating of oil on the inside for ya'.:D
  17. MAD MIKE
    MAD MIKE
    from 94577
    FWIW... what I like to do on stockish looking rebuilds
    Intake and WPs usually get sprayed in AL or Fe colors, whatever their natural color is.
    Damper and pulleys are usually gloss black with timing numbers/marks in yellow with base timing and TDC in red and white. Makes for easy timing checks.
    Simple subtle contrast will make an engine really pop.
    Black can hide ugly stuff, but it can also make a component disappear into the underhood ether.
    Lighter colors can also help you locate items when you drop them. Lot easier to find a dropped bolt on a AL colored intake than on a dark green or blue one.
    Paint the inside of the bell the same red glyptal color for electric motors. Often used for painting the inside of an engine for better oil drainage.
  18. That will then protect the paint. :)
  19. F-ONE
    F-ONE
    from Alabama
    And...
    Make it easier to wipe out.
    kidcampbell71 likes this.
  20. I paint the inside of em
  21. PhilA
    PhilA
    If it's been cleaned it should stick and stay.
    But, as stated, you need to leave a legacy in there. "I cared enough about this rebuild to paint in here, signed, dated"
    Rest of it looks really pretty though.
    nunattax, mad mikey and chevy57dude like this.
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
  23. Definitely paint it. If you ever do have oil splashing around, it will show up better, maybe not so much on black. I did mine in Chevy orange since I had a big can of it.
    mad mikey likes this.
  24. SEAAIRE354
    SEAAIRE354
    Was going to suggest glyptol but @MAD MIKE beat me to it.
    kidcampbell71, mad mikey and alanp561 like this.
  25. indyjps
    indyjps
    Paint it pink - it's internal o_O fun surprise for the next owner.
    Put it together man :D
    SS327, 327Eric, Eli Brown and 3 others like this.
  26. 51504bat
    51504bat
    Seems like all the parts I paint I end up signing my name to, in the form of a run not an autograph.:cool:
  27. I have never painted the inside of a bell housing but I never have given it any thought, I can't see where it would hurt so go ahead and paint it if you like. HRP
    VANDENPLAS, LWEL9226 and mad mikey like this.
  28. WB69
    WB69
    Paint it in my opinion. You painted the rest.
  29. Yes. Paint it real nice, you will will be glad later that you did now.
  30. '51 Norm
    '51 Norm
    from colorado
    I powder coated mine, I still don't know why.
