Hot Rods Paint problems - I'm restoring old steering wheel
Discussion in 'The Hokey Ass Message Board' started by guy1unico, Oct 5, 2019.
  1. guy1unico
    guy1unico
    This has happened to me before and it sucks. What am i doing wrong?
    Put 3 coats Krylon spray can gray primer on and 3 coats of Krylon gloss black spray on. Coat #4 started shrinking on me and pretty much wrecked 2 out of the 3 coats of black. What should i do now?
    Thank you,
    Guy in Dallas
  2. King ford
    King ford
    from 08302
    Well, your going to ha to sand it off until you get to material not wrinkled or shrink checked. Perhaps you didn't leave enough time for the aromatic chemicals to evaporate causing trapped solvent....put a coat on and let it DRY....repeat!
    Okatoma cruiser likes this.
  3. guy1unico
    guy1unico
    I'm in a hurry ...shoot...paint is an impatient man's dilemma.
    Thank you.
  4. Jethro
    Jethro
    I'd say follow the directions on the can . Some tell you to re coat within a certain time frame .If you take too long between coats you get the shrinkage or wrinkles. I spray a light dust coat for first coat then let it flash off , then progressively wetter coats letting them flash off until just tacky till you get complete coverage....then let it thoroughly dry until you can't smell the solvents coming out. That can take a couple days with some spray bombs.
    loudbang and Dirty Dug like this.
  5. Just a question but why 3 coats of primer? HRP
  6. s55mercury66
    s55mercury66
    from SW Wyoming
    Wet on wet will probably work best. You might try a different brand of paint also. The solvents in the paint are attacking the previously applied coat that is dry.
  7. 6sally6
    6sally6
    You using paint MADE for plastic?!.....(Of course you are)
    Whats that super-duper paint for plastic???.......Simco 100 or some such?.
    6sally6
  8. impala4speed
    impala4speed
    I used Dupli-Color gray filler primer on my steering wheel followed by VHT Epoxy gloss black paint.
    https://www.vhtpaint.com/specialty/vht-epoxy-all-weather-paint
    All coats of the Epoxy black were applied within an hour. After 2 hours you need to wait at least 2 days before applying anymore coats. Whatever paint you use it's very important to adhere to the wait times listed in their instructions.
    Frankie47 and loudbang like this.
  9. BJR
    BJR
    You did sand the primer before the color coat didn't you?
    Frankie47 and JNKYARDDOG_1 like this.
  10. john worden
    john worden
    from iowa
    Are you sure it's shrinkage? Shrinkage at failure level usually happens long after the paint dries.
    Describe better or post a pic.
    Are you sure it's not wrinkling?
    Frankie47 likes this.
  11. Perry Hvegholm
    Perry Hvegholm
    I must bear the patience of Job, then. I bought this aftermarket wooden tiller and hated the crappy stain job. So refinished it and laid down 8 coats of marine varnish. Took me two months, even with using Japan drier to speed the drying process.
  12. southcross2631
    southcross2631
    Try using real paint and a real paint gun. That's the way we paint steering wheels. 2015-08-12 12.29.00.jpg
    kidcampbell71 likes this.
  13. You have my attention. How has the black Epoxy held up?
  14. Squablow
    Squablow
    Also, how are the wheels being prepped? Old steering wheels get a lot of grease and skin oil soaked into them over time, which will also make paint lift, much like trying to paint a greasy engine or anything that got penetrating oil on it.
    Also, 3 coats of primer seems like a lot, unless you're spraying a coat or two, letting it get fully hardened, sanding it, and spraying the next coat. Sometimes thickness will make paint lift, because the solvents can't all get out. I have the best luck with spray paint in direct sunlight and high temps, which I'm guessing is due to how much solvent is in it vs. solids.
