The Southeast Gasser group requires aluminum radiators to be painted black. I painted mine with Black engine enamel . just wiped the tanks down with prep sol and sprayed it . Came out great no issues.
Hey Southcross , What kind of Hobart you got there,,,,,mine works great ? Some of the best money I ever spent . Tommy
If you want to pay for the name: Eastwood Radiator Black 12oz Satin Finish https://www.eastwood.com/ew-radiator-black-12oz-satin-finish.html
Don't forget...........light coats just for the color and coverage. Don't overdo it and affect the cooling capacity.
I painted my aluminum radiator with rattle can lacquer. Good coverage on the tanks, but just enough on the core to cover. No primer coat and it looked and lasted.
I wiped mine down with lacquer thinner then sprayed with VHT epoxy flat black. Looks good & resists chipping.
I had my Griffin aluminum rad for my RPU powder coated in a nice black using a high tech heat dispersion coating. I’m really pleased with it. https://techlinecoatings.com/tech-line-coatings/industrial-coatings/thermalmanagement/
Go on line and buy some entomologist's collection, paint the radiator black and while the paint is wet throw a jar full of bugs on it so it looks like it has been driven hard all summer. Radiator patina. Very cool.
On the truck I used an aluminum radiator that has a stamped upper tank so it looks pretty much like a brass and copper job. I considered painting it brass, then semi flat over the top of that and sand back through the flat paint on the edges and wear spots to reveal the brass below. I decided not to but I think it would look cool....and I often give advice I don't follow, it's how I raised my children to be good adults.
