packard ?
Discussion in 'The Hokey Ass Message Board' started by kustom beale, Jun 28, 2011.
  1. kustom beale
    kustom beale
    from ladner b.c
  2. rivguy
    rivguy
    With most round center horn buttons you would push down against spring pressure and turn counter clockwise. Of course be sure the battery is disconnected first.
  3. kustom beale
    kustom beale
    from ladner b.c
    the button or metal ring ?
  4. kustom beale
    kustom beale
    from ladner b.c
  5. SlmLrd
    SlmLrd
    from DAGO
    the ring should come off and the button with it. press, turn CC and it should pop off :)
  6. tommy
    tommy
    I'm not familiar with the Packard but if there are no screws on the back side to hold it then it will most likely be a push and twist.
    I do know that it can be a PITA sometimes. Usually there are 3 tabs spaced equally around the center that hold the ring on. Before it will rotate you must get all 3 tabs pushed down equally to allow the ring to turn. With only 2 of them pushed down it won't turn. Make sure you get it pushed in equally all the way around and then turn the ring.
  7. kustom beale
    kustom beale
    from ladner b.c
    thanks guys ,she is a tough one.lube ,leave,try again.
