Overflow bottle ideas
Discussion in 'The Hokey Ass Message Board' started by carcrazyjohn, Sep 14, 2010.
  1. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Need some overflow bottle ideas for my roadster .Post pics please ,
  2. Road Runner
    Road Runner
    An empty vintage bottle of this stuff....
  3. Flat-Foot
    Flat-Foot
    from Locust NC
    Maybe a PBR can? That's never been done before right??
  4. 5window
    5window
    That's really tough. Is it going to visible, or under your hood? These have never been one of Detroit's design strengths,so there just aren't any cool NOS ones. I think most of the a-traditional ones I have seen-canteens, beercans,mortar shells, oilcans,etc look pretty rat-roddy-but that's just my opnion, and what the hell do I know? You can see mine on my Model A,so I chose one of the "traditional" polished aluminum cylinders. Not very original, but it doesn't detract from the overall look of the car. I will be interested to see what you choose.
  5. I am using a vintage brass fire extinguisher on my model A . Hoping it dosen't give a R-R- look to it . Will edit my post with a pic when I get home from work ( is 1pm here at present)
    Edit , here's a pic of one the same as what I am using. Couple straps and it tucks in beside the grill shell nice and neatly.
      42.9 KB
  6. Buddy Palumbo
    Buddy Palumbo
    That's the same as HomemadeHardtop had on his green roadster (just sold it) - looks pretty cool .
  7. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Looking for great ideas and where to purchase a unique item or build No bottles ,I might be able to hide Im not sure yet in the process of mounting shell and fanshroud now along with trans cooler ,Open hood car ,Need some ideas .dont want the rat r d look .So far the extinguisher is a possibility
  8. embalming (sp?) fluid glass bottles are always cool.
  9. Engine-Ear
    Engine-Ear
    Alliance Vendor
    he said he doesn't want a bottle...I would look into a vintage can that suits your dimensional requirements. eRape has a sh!tload of vintage cans from every conceivable product and you can often find them for under $30 in good shape.
    Then, you get the can, punch an appropriate hole in the cap for the overflow line and add a vent hole on the top of the can somewhere.
    Down the road you go. ...my $0.02.
  10. blue 49
    blue 49
    from Iowa
    Here's mine. It's a piece of aluminum conduit with ends I made welded in and then finished in the lathe. Painted black so it isn't too street roddy.
      50.2 KB
  11. RatRoy
    RatRoy
    I assume everybody has a shut valve on the outlet of the overflow bottle..?:confused:
  12. mart3406
    mart3406
    from Canada
    A few years ago I made a kind of slick
    looking overflow can for a buddy's drag
    car using an old aluminum army canteen.
    I mounted the canteen 'upside-down' so
    that 'cap end' faced down. Being aluminum,
    the canteen could be tig-welded, so I made
    a mounting bracket for it out of piece of
    scrap 3/16 aluminum plate welded to the
    side of the canteen. To connect it to the
    rad, I drilled a hole into the "top" (of the
    now upside-down) canteen and welded in
    a small (dash-2 or dash-3), aluminum
    '90-degree' AN fitting that connected to a
    similar-sized AN 'straight' fitting that I
    expoxied into the brass radiator neck and
    connected with a length of braided line.
    Mart3406
  13. 53sled
    53sled
    from KCMO
    I used a mountain dew bottle in my chevelle once, and a 32 oz monster can in my daily.
  14. there is a post on here somewhere that shows an old cannister type oil filter used as a coolant overflow tank, looked great.
  15. guitar man
    guitar man
    from Tulsa OK
    What about a motorcycle oil tank? There's a lot of different designs but I always liked these back in my chopper days.
  16. 56oldsDarrin
    56oldsDarrin
    Its a bit dirty nowdays, but...
  17. Flat-Foot
    Flat-Foot
    from Locust NC
  18. bonez
    bonez
    from Slow lane
    Please explain!
  19. stude_trucks
    stude_trucks
    I just use an old 50's 32 oz glass soda bottle and made a simple little metal bracket to hold it. Since it is glass, it is easy to see how full it is and then when I want, I just pull the hose out of the top pull the bottle out and dump it back in the radiator and replace, very easy and simple.
  20. Drawn aluminium hair spray can works for me.
  21. i uses an old all metal castrol motor oil quart can as an over flow i have another on if you want one
  22. This a "street rod" style aluminum overflow with a twist, our local powdercoat guy, Wes at Supeior Powder Coat, has a coating that looks like copper and it looks old timey and matches my underhood metallic colors. Just an idea that could be coated in other colors or textures and hard to deny the easy mounting of these units.
  23. mart3406
    mart3406
    from Canada
    Hey....very nice looking shroud on that
    rad too! Very slick!
    mart3406
  24. hmm
    the non r.r. approach
    gas tank from a back pack vintage gas powered leaf blower its a tall curved tank kinda like that big flask shown
    check some bigger mowers or tractor tanks too
    use the resivior from a late fifties ford 58-60
    vettes used em too .. as the radiator was lower than the resv. tank cap
    all metal thermos new -vintage plaid
    old turpintine can or simular
    modern over flow tank tightly wrapped with canvas,leather ,old cycle inner tube.. its done just modern ugly
    glass rolling pin.. see gramma's kitchen
    old bicycle pump brass -painted
    old insect sprayer
    home made out of any type of tubing brass , square , aviation strut.. go to the scrap pile or recycling
    dont forget the right cap ifn you are doing a closed system
  25. RatRoy
    RatRoy
    If you have a coolant recovery system the overflow can works great. If you don't have a coolant recovery system the shutoff valve on the can will allow you to dump the extra coolant where you chose. :)
  26. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    There was a large thread on this a couple years ago, search "puke tank", overflow....
  27. What GUITAR MAN said. I used a poly oil tank from a Suzuki Moped Fit like Factory. painted it black...blends right in with the frame, etc. Opening for the tube is right at the bottom. Unless you're looking for it, it's hardly noticeable...
  28. GassersGarage
    GassersGarage
    My '31 use a polished "Asahi" beer can. My '51 has a front mounted "Moon" tank which I use as an overflow.
  29. Von Rigg Fink
    Von Rigg Fink
    from Garage
    i still havent delt with this issue..
    i want to hide mine..possibly under the radiator..i got some room , its just finding a small tank that will fit.
    i hate looking at them..they are so ugly
