"other" steering boxes
Discussion in 'The Hokey Ass Message Board' started by 46international, Sep 13, 2012.
  1. I have a 40-41 Chevy half ton truck gear for my T. Mounts easy and looks nice. Even less bulk then a f1 gear. My .02.
  2. silversink
    silversink
    Been driving my 48 Int. kb1 for 35 years with one of those weak boxes. If you keep them lubed and adjusted they are a good box that fits most anywhere you want to put them.
  3. There's a "tech" in the current streetrodder on different columns/boxes
  4. NealinCA
    NealinCA
    I like the '37 Hudson boxes...but they aren't usually the low price leader...
  5. falcongeorge
    falcongeorge
    from BC
    The ross is a pretty distinctive looking box, fits well, and was a popular alternative to the ford box dating back to the dry lakes days. Alot of them in old race cars. I am seriously thinking about one, primarily for the period look, and the fact that its a box that you rarely see used anymore. If there is anyone out there running on in a light (1900-2100lb) car, I'd like to hear what you have to say, pro or con. Benno, I have a late fifties chevy PU box on hand, slated for a future project, but not for this one, too new.
  6. Falcongeorge, sorry I did not get to post up the photos last night (i had to work on some other things)
    the Ross box in my international is the same as the one in the photo in post #13.
  7. RustyNCA
    RustyNCA
    I just finished converting our F100 box steering shaft to run either a Ford splined end or a GM splined end in our 29 coupe. I picked up an Oldsmobile deep dish wheel I wanted to run and learned that yes.... Ford and GM wheels don't crossover...
    The F100 box seems pretty solid and easy to steer.
    RustyNCA
  8. falcongeorge
    falcongeorge
    from BC
    No problem, I have pm's I still need to answer from a week ago.:eek: It was actually the cast in mounting flange I wanted to see. Is it a three bolt deal with the sector shaft passing though the middle?
  9. The photos below are from Steve Lang. Steve is a great fan of these steering boxes and has used one on his Willys build (there's a build thread elsewhere on The HAMB) in preference to a Vega.
    After
  10. willymakeit
    willymakeit
    Just when I had about decided to cowl steer with a F150 box, here comes more options. At least I have better chances in the salvage yard. Theres one about 30 mi. from me that has farm equipment I can look at for ideas.
    Thanks for the new thread.
  11. nali
    nali
    Not the steering box, but this is a power steering pump from a 1968 Javelin AMC, IIRC.
    Different than the GM everybody use.
  12. marioD
    marioD
    Excellent, thank you.
    i like the look and i guess it won't be too hard to get one 'over here'....
    Mario
  13. nali
    nali
    This is a piece of art :p
  14. oldspwr
    oldspwr
    Has anyone ever used a 58-64 Impala Saginaw box for cross steering? I have two boxes from '64 Impala power steering cars (still a manual box but they used slave cylinder assist...) They are 20:1 ratio and seem to fit with my Y block... I know they have to be reversed but there are a few good threads on here on how to reverse them...
  15. Hotwhilz
    Hotwhilz
    from France
    Samr thing I did on the 38 I'm building, the reason I used it is that I saved a 58 Gm column and shaft from a previous power steering upgrade.
    fits in the 34 rails, just had to reshaped the pitman arm to fit my bill!
    As far as steering wheel, I'm going for a 4 spoke indy type also!
  16. classic gary
    classic gary
    525 box as cross steering has to be reversed? It's just a larger version of a vega box. Or are you meaning the pitman arm has to be removed and reinstalled to the front.
  17. oldspwr
    oldspwr
    Actually the box has to be 'reversed' like they did in this thread...
    http://www.jalopyjournal.com/forum/showthread.php?t=730818
  18. PackardV8
    PackardV8
    Back to Ross boxes - Studebaker used them on cars and trucks and the first mod on any performance Stude build is to get rid of the Ross box; they're pretty much cheap junk. I wouldn't install one like Stude used if it were NOS and free.
    First problem occurs when the output shaft wears the seal and all the heavy oil leaks out. Then the box wears really fast. Most I find have been filled with grease because oil wouldn't stay in there.
    The Saginaw recirculating ball boxes were much, much better. Studebaker finally went back to them on the last of the '60s Larks.
    jack vines
  19. I have to agree, the Ross box in my international is bad, But I think they also made some with bearing mounted "studs" that ingage with the worm shaft, they may be better as far as steering effert goes.
    The one think I have to say is get the CORRECT oil in the box much better than just grease. so make a new bushing for the sector shaft and install a new seal.
  20. Oldblueoval gave me a couple of Jeep manual boxes (79-81)that apparently were take offs for power steering conversions. We used one for cross steering on a recent roadster build and it steers so well that we are now using the other one on a A sedan project.
  21. willymakeit
    willymakeit
    I used a 65 Impala box to cross steer my 56 F100. Don't know if they were different before or not.
  22. aonemarine
    aonemarine
    from Delaware
    I'm going to be getting into this part of the build soon. But I want to keep my headlight switch right where it is in the stock wheel. Am I stuck using the a box???
  23. classic gary
    classic gary
    i dont think so, cut the shaft, double D it, u-joint it to your desired box.......
  24. Torkwrench
    Torkwrench
    I'm using a 59 Chevy 1/2 ton box and column, in my 34 Chevy Master coupe. The 57 - 59 Chevy / GMC boxes and columns are all the same. 55 - 56 1/2 tons have the same steering box, but with a longer column. I'll be using a 59 Impala steering wheel.
  25. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    I'm using a 46 ford pickup box
  26. PackardV8
    PackardV8
    Are '55-59 pickup steering boxes worth anything? I know a couple which will be going to scrap soon. They'd be a PITA to ship.
    jack vines
  27. Im running a 37 Hudson box on my A, its a Gemmer box and they work great but the downside is they are getting very hard to come by and are probably not for a budget build if you can't do the mods by yourself.
  28. I know that will adapt the column to a later box; but how does that address the horn rod and light switch?
  29. aonemarine
    aonemarine
    from Delaware
    Thanks Rich, guess I could have told them it was a model A, most people dont know how thier headlamp switch works....
  30. classic gary
    classic gary
    True, me included, but, can't you cut the column/shaft, cutting the assembly as long as you can, then cut the column tube/housing/rods a little shorter so everything is the same only shorter, then double d the shaft for the rag or u-joint to the steering box.
