Other Ford 5 or 6 speed transmissions?
Discussion in 'The Hokey Ass Message Board' started by Thorkle Rod, Jun 10, 2009.
  1. Thorkle Rod
    Thorkle Rod
    Are there any other "strong" factory 5 or 6 speed manual transmissions besides a T5 that will bolt up to my 1965, 289? I'm thinking they didn't put a T5 into trucks and that they used something else but haven't been able to find much.
  2. Weasel
    Weasel
    Tremec TKO 500 or 600
  3. R Pope
    R Pope
    Trucks used the M5 Mazda-built trans. The small-block version has a co-ax hydraulic TO bearing. They are an integral-bell trans so don't adapt to other engines easily. I have one I'm putting on a 351W.
  4. willowbilly3
    willowbilly3
    from Sturgis
    I guess the T-bird super coupes used the Mazda M5 tranny. I'm not sure if the internals varied much from the pickup, pretty much the same I think. Also the big ZF 5 speed came in a small block pattern too. I have one behind a warmed up 300-6 build in my shop truck and I like it pretty good but wouldn't consider it much for gear slamming. It is basically the same tranny used behind 460s and Power Stroke diesels.
  5. amsvette
    amsvette
    If you want to spend some money, try Keisler Engineering. I just bought a T45 5 speed conversion kit for my '65 Mustang. Its a little more robust than a WC T5 and Keisler converts them from integral bell housing to one that will work with a separate bell housing. It was a little spendy but it has EVERYTHING needed for the Mustang conversion plus it has a waranty that doesn't start until the car is done!
  6. Crusty Nut
    Crusty Nut
    Use an M5R2. It it the mazda trans they put in the 1/2 ton pickups. They have a small block belhousing. I'm putting one in my current project.
  7. Flat Ernie
    Flat Ernie
    Tech Editor
    Turbo/Super Coupes used the T5
  8. tjm73
    tjm73
    The Tremec showed up in mid 2001, but it's not like a stick shift of old. It has a very modern mount up pattern. The bellhousing is not normal looking either.
  9. Greg55_99
    Greg55_99
  10. bluebolt
    bluebolt
    from Benton LA
    Turbo 4 cylinder cars used the T5, the V6 Super Coupes used a variant of the M5OD-R2 with different gear ratios. I think these are the gear ratios. Stronger than the T5 but harder to rebuild.
    The 89-93 ratios are
    5th (0.75)
    4th (1.00)
    3rd (1.43)
    2nd (2.32)
    1st (3.75)
    The 94-95 ratios are
    5th (0.75)
    4th (1.00)
    3rd (1.34)
    2nd (2.16)
    1st (3.42)<!-- / message -->
