OT: What rear end is under a Mustang II
Discussion in 'The Hokey Ass Message Board' started by fiat128, Sep 23, 2008.
  1. fiat128
    fiat128
    from El Paso TX
    Sorry for the off topic post but I need to find a rear diff pumpkin for a 77 Mustang II quick and was wondering what all will fit. I'm sure this group can answer quicker than me trying to figure out where to ask (there probably is a Mustang II forum somewhere) You can PM me or post if here if everybody doesn't get too riled up about it.
  2. skwurl
    skwurl
    Not positive but an 8 inch sounds right
  3. plainoldmustang
    plainoldmustang
    from Ohio, USA
    It's a Ford 8", they are fairly common. Oddly enough, a LOT of MII's got 3.40:1 posi pigs from the factory. :D FYI its 57.25" flange to flange overall width, 4-lug axles. Fits nicely under an early Mustang too. :D
  4. skwurl
    skwurl
  5. Kustomkarma
    Kustomkarma
    Is the bolt pattern the same as early Mustang / Falcon six cyl (4 x 4 1/2?)
  6. skwurl
    skwurl
    Should be 4 1/4 x 4
  7. Dirty Dug
    Dirty Dug
    Wouldn't that V8 models have five lug like the Maverick 8"?
  8. skwurl
    skwurl
    Later v8s didnt. Not sure when they started all 4 lug
  9. No.
    Thanks,
    Kurt
  10. Puddin Head
    Puddin Head
    from Mason, Oh
    All Mustang II were 4 lug cars. If you wanted you could use the Maverick 4 lug 8" rear.
  11. fiat128
    fiat128
    from El Paso TX
    Yea, just that part. The car will be getting a 302 in it and I was wondering what I might find used cheap.
    One other question, can it be flat towed without it? I assume not since nothing is supporting the end of the axles.
  12. No, but the good news is they are REALLY easy to drill because if you pop out the other 3 lugs, the remaining one is where it needs to be for the 5 lugs. Mic off the center and go.
  13. Arizona Geezer
    Arizona Geezer
    8 inch...........I took a 3:55 center from a Mustang II and used it in a Maverick 8 inch in my Studebaker.
  14. I believe any Ford 8" center section should work. I'd go to a self-serve junkyard and get a whole rear end. Also, post a wanted ad here. How far are you from FlatTopBob's yard? If you're looking for a "posi", you might see what a new one costs.
    Thanks,
    Kurt
