Here is an original airplane seat. It is made of phenolic, which was an early resin and cloth compound used to make parts on airplanes. Has the same appearance as the other highly desired bomber seats. I only have one, so it would be good for a one seater TROG racer or belly tank or something similar. Seat does have corrosion that is on either side of the inside of the back portion. And also has the river holes drilled out in the seat bottom brace. Corrosion could probably just be fixed with resin, or leave as is for the patina. $500
