I just picked up a 53 Merc Monterey 4 door. Car is straight and retains its original paint with only a few specs of surface rust here and there. Unfortunately, it seem that someone at some point decided to try and protect the car by brushing on some sort of sealant. not sure what it is but its clear/matt and its flaking off in some areas. Any ideas on how to remove this so i can attempt to clean up the original paint? Any ideas would be greatly appreciated. Pics of car soon to follow. Lance
View attachment 2192967 View attachment 2192968 View attachment 2192969 On the trunk is where you can really see the mystery haze flaking off. Posted using the Full Custom H.A.M.B. App!
If you want to preserve the original paint - and I really hope you do - consult a professional before you do anything. All automotive paint stores - the ones that supply body shops with their paint supplies - have access to factory reps who have the background and knowledge to diagnose paint problems. That's what they do. Take advantage of this service. Beats the heck out of screwing up the original paint by using some inappropriate chemical or technique...
Good call on the paint shop, I do want to preserve the paint and I'm trying to exhaust all options before changing it. The pressure washer might work on the flaking areas but others are still well intact. I'm wondering if a wet sand would do the trick. It is kind of like a clear. Posted using the Full Custom H.A.M.B. App!
It might be Cosmoline. In that case, you just have to wash it with hot water. Has to be hot though, cold won't do shit. If it's varnish or shellac, you'll have to figure out a solvent that will take it off without softening the old paint underneath. I would suggest against a wetsanding, the paint already looks thin on there and trying to wetsand through a brushed on layer of shit and then stop at already thin paint? Recipe for disaster.
Agree with Squablow, test different solvents in areas that aren't visible, see what cuts into the "clear". I'm guessing polyeurthane or some sort of clear varnish, something meant for wood, so mineral spirits or acetone as a solvent. Not sure what type of paint was originally on that car and what solvents will cut into it. Verify. Be safe, spreading enough solvent to cover a body panel makes a lot of fumes, respirator and work outside, in the shade.
