This is the frame i mentioned in a post with some other 32 ford stuff ,all out of long dry indoor storage. As promised i am listing the parts separately. Frame is very straight and solid. Original crossmembers still factory riveted . Has a few minor issues.The worst is a small hole,about 1 1/2 inches in diameter in the k member right behind where the pedal box mounts.Easy fix and it won't be seen but it's there. A few small patches of pitting, mostly on the tops of the frame rails and some on the top of the front crossmember.The front frame horn( drivers side) has a weld vertically along the face.Again,no big deal and an easy fix but it's there. The metal is not pebbled from rust or thin and should be a great frame to work with.It has a very clear factory v/8 vin with the star on each side.If you want to start your project with a nice original frame or rebuild an old hot rod that has had the frame butchered this would be worth a look.PM me for more pics or info.Asking $3,700.00 or close offer. Bob
Bump The VIN # on this frame has been checked by the State Police. The Number is clear in all 50 states and ,of course, does not come back a "hit" (stolen). Bob
