I have a extra 39 ford dashboard steering column mount. This is a nice piece to use when building a Model Av-8 with a later tradition steering box like a f100 ,f1 or a 1932 1933 1934. You can also use it in a 1939 ford and believe this column mount is also used in the 1940 1941 pickups. The condition is good but one of the mounting holes had to be retapped after the mounted bolt got broken in the mount as most do, so redrilled it and threaded it same size 5/16-24 . Last picture show a 1936 column mount with a f100 column . If I wanted to drop the column a bit lower I would have used the 39 drop. It also has a 1936 dash in the 1929 roadster .. Looking to get 75 bucks plus shipping of 10 bucks. Thank you
