Hot Rods Opinions on hood scoop wanted
Discussion in 'The Hokey Ass Message Board' started by grimmfalcon138, Jul 15, 2017.
  1. grimmfalcon138
    grimmfalcon138
    from az
    So I have been considering some sort of hood scoop for the Plymouth. I made this cardboard mock up, but I honestly don't know if I like it or not. Opinions wanted, or suggestions for something else? Be honest, I can take it. Thanks in advance. 20170715_115302.jpg 20170715_115319.jpg
  2. You ask for it so here come's the truth ~ It's as UGLY AS A MUD FENCE! HRP
    dana barlow, 5window, slim38 and 2 others like this.
  3. That's pretty wrong for that car .
  4. Is the scoop under your lunch kit?? Seriously, though, that's not the style of scoop for that car. Maybe a baby bird style??
  5. stuart in mn
    stuart in mn
    What engine combination is under the hood? What's the theme of the car, is it a drag racer or whatZ
    Just Gary likes this.
  6. Don't you have a small scoop on the car?
    If you just have to have a bigger scoop use something that would have be available back in the day,something similar to this.HRP
  7. grimmfalcon138
    grimmfalcon138
    from az
    This is what the car currently looks like. HRP, thanks for the honesty. I guess I was just itching for something different, I get bored easily.
    Stuart in nm, I've never really stuck to any sort of "theme" with the car. But if I had to classify it? Street freak-ish. 20170715_123829.jpg
    dana barlow likes this.
  8. chopped
    chopped
    Go for it, if you have a strong sense of humor.
  9. Sheep Dip
    Sheep Dip
    from Central Ca
    Put a spacer under it and you now have a full scoop.
    Hdonlybob likes this.
  10. Put a spacer under the hillybornish scoop, let it stand up and out a bit more and finish the hoods edges.
    Or
    Maybe a surfers scoop type unit on the hood.
  11. G-son
    G-son
    from Sweden
    Are you just chasing the right look, or do you want something that's actually functional?
  12. Gman0046
    Gman0046
    Nothing wrong with hood scoops but the OP's cardboard mock up looks like shit. Nothing could look worse.
  13. upspirate likes this.
  14. tfeverfred
    tfeverfred
    No. Boredom has killed the look of a lot of cars. Sometimes, it REALLY is DONE.
    belair and scotty t like this.
  15. TVC
    TVC
    A reverse tear drop or is that too Thunderbolt? It would sure look neat with those rounded fender tops and all but might be too closely associated with Ford to pass.
  16. chevy57dude
    chevy57dude
  17. tfeverfred
    tfeverfred
    That's about right.
    chevy57dude likes this.
  18. grimmfalcon138
    grimmfalcon138
    from az
    Thanks for the input guys. I think I'll just leave it alone.
  19. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>I think I'll just leave it alone.>>>
    No!!! You gotta get rid of the scoop. Then replace it with a new grille. A valiant 300! That might be even more street-freakish. 8^) Jack E/NJ valiant.jpg
  20. sunbeam
    sunbeam
    Cowl type no taller that required. I like Fords but to me those teardrop scoops didn't even look good on the cars Ford put them on.
  21. c-10 simplex
    c-10 simplex
    If YOU like it, then go for it; That's all that matters.
    i would go for the Hilbourne (sp?) you have on it now, or a bugcatcher myself.
  22. Something that goes with the lines of the car and hood shape.
    Pretty recognizable, maybe too much.
    But better.
    Surfer style scoop
    If you're feeling ambitious.
    Carve one out of foam and patern it.
  23. 49ratfink
    49ratfink
    even made from metal that scoop would look like a cardboard box.
  24. s55mercury66
    s55mercury66
    from SW Wyoming
    What you have on there now looks '60's as can be. Some stainless trim surrounding it would help to set it off a bit.
  25. smitron
    smitron
    from texas
    The thing looks good and sneaky as is without the box treatment. Put spacer under it if u have too for the full hilborne visible effect. I also really like the smooth red plexiglass thing someone posted earlier.
  26. upspirate
    upspirate
  27. Flathead Dave
    Flathead Dave
    from So. Cal.
    Give the box to the cat.
    Cosmo49 likes this.
  28. And to be perfectly honest it was the ugliest thing about the whole car.
    The hood scoop on the car when it was used in American Graffiti looked a 100 times better.HRP
    upspirate and chevy57dude like this.
  29. big duece
    big duece
    from kansas
    The rest of the '55 makes up for the bad scoop. Like to girl that has the killer body, and bad nose.
    5window likes this.
