Art & Inspiration OOPS ford flathead engine
Discussion in 'The Hokey Ass Message Board' started by Flatheadjohn47, Nov 22, 2020.
  1. Ordering parts from Speedway/person on the other end of the phone was an ex-machinist who had worked at speedway for years. Conversation turned to flatheads(I have over 55 years experience)with flat-motors and I was the salesman(friend of the buyer) for the French flatheads that came into Texas in the late 90’s. He asked me if I had heard of the Ford OOPS motor. I said I had never heard of them. When he was a machinist in the 90’s, he was rebuilding a motor and ordered new cam bearing as part of the package.He went to install them and found they “dropped” thru the normal bores that held the bearings. The “tunnel” was .020 LARGER than it should have been. He did some research and found Ford had mistakenly cast around 1,000 engines before discovering the OOPS. They manufactured 100 sets of .020 oversized cam bearings rather than scrapping the “mistake”. All 100 sets were purchased by Red’s Headers out of Cali and he purchased a set to complete his overhaul. He said Ford called it the OOPS motor; something I never heard of!
  2. Jason Mitchell
    Jason Mitchell
    Interesting. Ive never heard of this either.
  3. jimmy six
    jimmy six
    If Red Hamilton did it .... it makes sense.
  4. dirty old man
    dirty old man
    Back "Inna Day" things like this happened. Another example of this was with Mopar flathead sixes in that you had to be sure of rod and main bearing sizes, as some came with undersize journals and corresponding bearing inserts to match. Sometimes it was only on some journals.
    Desoto291Hemi likes this.
  5. 51504bat
    51504bat
    Don't know about Fords but my old boss rebuilt a Rambler 6 for his MIL and came to find out that it had oversize cam bearings from the factory. Chased low oil pressure until he figured out the cam bearing issue. Installed a set of oversized bearings and all was good.
  6. Jalopy Joker
    Jalopy Joker
    learn something new every day, hopefully
  7. BamaMav
    BamaMav
    from Berry, AL
    Old Henry didn't believe in letting anything go to waste. That's why parts were used until they were used up, even if they were for last years model. Over the years, I've ran across things that shouldn't be a certain year model, but were, just for that very reason....
    lucas doolin likes this.
  8. continentaljohn
    continentaljohn
    Interesting and easier to make a oversized bearing then scrap a bunch of blocks. Thats what I call “plan B “ to a oops
  9. Flathead Dave
    Flathead Dave
    from So. Cal.
  10. 5window
    5window
    Interesting story. I'm wondering why they only cast 100 sets of bearings for the 1000 engines?
  11. saltracer219
    saltracer219
    The auto manufacturers regularly repaired mismachined blocks and heads. When I restored the Orange Crate Olds engine I discovered that some of the original lifter bores had been bored .020 oversize by the factory.
    stillrunners and Desoto291Hemi like this.
  12. alanp561
    alanp561
    Typo??????o_O:confused:
  13. Phil P
    Phil P
    Maybe 100 service replacement sets, on top of the 1000?
    Phil
  14. I reasoned that out of a thousand or so Motors, maybe 10%or about 100 would be overhauled to make a few more miles. Don’t know for sure,just a guess!
  15. seb fontana
    seb fontana
    from ct
    BS. But what do I know.
  16. Raunchy
    Raunchy
    Mine were oversized. Couldn't find any replacements. So Gary McGlasson made some. Worked out fine.
    stillrunners likes this.
  17. lucas doolin
    lucas doolin
    Ford reused 1941 passenger car tail lights on 1950s panel trucks.
