Oooops!
Discussion in 'The Hokey Ass Message Board' started by rbradber, Mar 16, 2012.
  1. rbradber
    rbradber
    from Choctaw
    Some days it just doesn't pay to go out to the shop. Luckily no damage to the car and no heart attack.
  2. raidmagic
    raidmagic
    Woah!!! What happened? Did a cable fail or a lock?
  3. metal man
    metal man
    That's the stuff bad dreams are made of. I've actually had that bad dream. We all need to know exactly how that happened,even if it's embarrassing.
  4. Yowza! That's some scary stuff!
  5. castleman1111
    castleman1111
    Yes!! Let's hear the details!! May save a life!! Damn!!!
  6. that's not an oops, that looks more like an o-crap.
  7. KooDaddy
    KooDaddy
    from Wis.
    Looks like home-made design here and I'm NOT KNOCKING IT but think more on safe guards so this doesnt happen in future.
    Good luck.
    And again this isnt meant as a slam.
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    It wouldn't hurt to bolt the legs of a lift to the shop floor.
  9. DdoubleD
    DdoubleD
    from Michigan
    POS Chinknees?????
  10. Weasel
    Weasel
    I had something similar happen and no damage but elevated pulse, sweaty palms etc. it happens when you do not pull the release lever far enough so all the stops disengage. One or two hang/remain engaged and that is the result....
  11. graveyardsledder
    graveyardsledder
    That's a shit ya pants moment. I've seen it happen twice, one was on an inground lift and one of the lock mechanisms broke and sent the truck down at an angle. Ended up twisting the frame. I've never seen upclose an above ground lift fail. That sucks for your heart but glad the car is okay!
  12. Mr48chev
    Wooh, that's spooky. What was the cause of that. Broken part or part not engaged properly?
  13. tommyd
    tommyd
    from South Indy
    Wow! thats not a good thing to see on a Friday night!
  14. Well that just sucks!
    But I have to ask.....
    Was that a Bend-Pak or a Harbor Fright???
  15. PRIMERDAVE
    PRIMERDAVE
    Holy pucker factor Batman!!!!
  16. damagedduck
    damagedduck
    from Greeley Co
    a local guy had some thing like happen with a totaly different ending,{killed him}
    go buy a lotto ticket!
  17. rbradber
    rbradber
    from Choctaw
    Looks like a pulley seized on the shaft and twisted it off. It is a quality hoist but I definitely will be lubing the pulleys and checking them from now on.
  18. Seriously..... What brand is it???
    AND
    Did the car get any damage???
    I'm able to ask these questions because it's obvious that you're okay.
  19. rbradber
    rbradber
    from Choctaw
    The legs are bolted to the floor and the "home made" thingy is the A frame that I lifted that side up with.
  20. WOW !!!You must be irish. Best go buy a lottery ticket or two. I keep a close watch on mine anytime I raise or lower it. Anybody that has a lift bolted to the floor CHECK the nuts as they will tend to loosen up & lube all the pulleys & locks occasionaly. Lifts need PM just like any thing mechanical.
  21. metal man
    metal man
    Good thing there was nothing in the bottom bunk!
  22. 325w
    325w
    from texas
    Weasel hit it the nail on the head. friend has one like that and has had the mishap happen twice. So far no damage. His is a good lift. He juist failed to pull the release hard enough. The lifts should be lubed ever so often also.
  23. drptop70ss
    drptop70ss
    from NY
    Man you are a lucky one! Looks like a propark 7 or similar, I have 3 of them. I use them for storage only, I dont trust them enough to work under them, every time I am raising or lowering them I am constantly watching all 4 corners for any signs of trouble. The newer ones have better locks similar to a backyard buddy, earlier ones are a bit more dicey but work.
  24. Normal Norman
    Normal Norman
    from Goshen IN.
    I can't remember the brand name but it looks just like mine, came out of Texas. Never had a problem with it but you gotta watch it when lowering to make sure the locks release. I don't have mine bolted to the floor, its supposed to be mobile around the shop if needed, it came with wheels that are removable. Normal Norman
  25. putz
    putz
    from wisc.
    Weasel , had the same thing happen ,scared the hell out of me!!!!!!!!!
  26. tjmercury
    tjmercury
    Whoa! That was a heart sinking moment for sure! At least you and the car are ok.
