Projects ONE PIECE AT A TIME ('47 FORD COUPE)
Discussion in 'The Hokey Ass Message Board' started by topher5150, Mar 1, 2017.
  1. topher5150
    topher5150
    Made a little progress today. I picked up Granada rear end today and I have some more questions.
    1. What is the part that connects the brake lines and the vent called?
    2. How do I get a rounded, rusted drain plug out?
    3. If I turn the pinion about two and a half or so turns, is it safe to assume that I have about that ratio?
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  2. NewGuyOldFord
    NewGuyOldFord
    It's just the rear hose. The vent nipple comes out and the hose will come off seeing how the nipple is just a hollow through bolt. Get a rear brake hose from a 70's f100/150 2 wd because they are about the longest factory rear hose of that configuration. That rear is probably a 2.79 ratio.
    topher5150 likes this.
  3. flatout51
    flatout51
    The car is too low to get a good picture right now bit I can try and describe it? I took just a flat plate that bolts to the bottom of the x member then welded a peice of square tubing to the top side for a sort of spacer. With a hole cut in the middle of the bottom plate to reach the trans mount stud. I'm using an S10 tailshaft so the mount only has one mount stud on the bottom. I'll try and get the car up soon to get a pic.
    Sent from my SM-N960U using The H.A.M.B. mobile app
  4. flatout51
    flatout51
    I hope that description helps... I'll try and get the car up soon to get a pic
  5. topher5150
    topher5150
    almost took me a whole day, but praise God I got it home. I hope I don't have to do this again any time soon IMG_20190427_130311224.jpeg IMG_20190427_162118210_HDR.jpeg IMG_20190427_171419026.jpeg
    40ragtopdown likes this.
  6. topher5150
    topher5150
    All the pics you see about Detroit that was this place. It was like I drove on the set of Robocop
    treb11 likes this.
  7. slv63
    slv63
    What’s the story with the sedan?
  8. topher5150
    topher5150
    I need some floors for my coupe and it has a Ford frame.
    slv63 likes this.
  9. For the drain plug, I welded a bolt into the plug on mine.. Easy to grip with a socket and ratchet, then. Once you get the first turn, it comes out fine. Just replace with a new plug. The little bit of heat from the welding also helped break the rust "bite"
    Atwater Mike and topher5150 like this.
  10. topher5150
    topher5150
    I don't know how much I can weld on to it there's a stud right next to it
  11. topher5150
    topher5150
    Finally got the trunk off. The toolbox area is pretty rough but a lot of good sheet metal in the car. Found some shiny bits and window trim. IMG_20190428_121401849_HDR.jpeg IMG_20190428_121456600.jpeg
    slv63 likes this.
  12. topher5150
    topher5150
    Does anyone know what size shackles, and front bushings Chassis Engineering used on their rear end spring kits?
  13. topher5150
    topher5150
    Doing some thinking out loud about how to do the floors, and here's some ideas I came up with floor1a.JPG cut close to where the replacement panel company has theirs cut
    remove spot welds under toe board
    This one can go a lot of ways, but if I can maybe I can patch the seating area and just cut along the red line. The trunk area is rough on both cars so I may just cut that out entirely and replace that.
    oliver westlund likes this.
  14. BigChief
    BigChief
    2-1/2 inches.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  15. BigChief
    BigChief
    CE plate and 2" radius rod ball drop on my 48 2dr sedan. I fitted for either BW T10 or Tremec T170FT....T5 should be no problem at all. You'll need to make sure you have a straight shot for the speedo cable....make a hole in the X member. FB_IMG_1557841383252.jpeg
  16. NewGuyOldFord
    NewGuyOldFord
    Hey Topher, did the sedan by chance have the interior pillar dome lights?
  17. topher5150
    topher5150
    I think there is one, but not sure the condition.
  18. NewGuyOldFord
    NewGuyOldFord
    I'm looking for one so let me know. Thanks.
  19. topher5150
    topher5150
  20. I kept the flap from a shackle kit, marked Flagg Suspension Products part # FS771. I think it was from the CE kit I used. It was also marked, S18861. Try those part numbers in a Google search, see what comes up.
  21. 40ragtopdown
    40ragtopdown
    This is what chassis engineering sells.you may be able to cross reference them to another brand if you want to buy them locally. 20150728_174653.jpg 20150728_174528.jpg
  22. topher5150
    topher5150
    I tried googling that part number but I kept getting wierd semi truck shackles
  23. topher5150
    topher5150
    found them thanks....got to love rock auto
  24. sliceddeuce
    sliceddeuce
    Re; trunk pic w/ jack handle....Who else thought that beam of light shining on the floor was the ground under the car???..Carry on Chris. JB
  25. topher5150
    topher5150
    look in the spare tire hole just to the left of that and there's plenty of daylight coming through there
  26. topher5150
    topher5150
  27. topher5150
    topher5150
  28. topher5150
    topher5150
    I got the bushings put in my spindles and thought I'd try reaming them at work..... They're sitting in the shop waiting to get new bushings and machined professionally.
    On the bright side I got the old suspension out for the new one... Working smarter this time IMG_20190524_184113701.jpeg
  29. topher5150
    topher5150
    Got the new cross member in. Couldn't get my giant meat hooks back there to hold the nuts and washers in place so I super glued the washers to the nuts.
    This is what I get for buying u bolts from a place that deals in heavy equipment IMG_20190526_094400772.jpeg IMG_20190526_094411255.jpeg
    bobss396 likes this.
