One hole don't fire??????
Discussion in 'The Hokey Ass Message Board' started by old beet, Apr 28, 2010.
  1. old beet
    old beet
    460 Ford in my 49 Merc. #4 don't fire, changed the plug and wire, no spark. Can it be as simple as a cracked cap? No noise like a bent or loose pushrod? Thanks......Beet
  2. UnsettledParadox
    UnsettledParadox
    when you say it doesnt fire. does that mean you are getting no spark to only that cylinder or is it physically not igniting?
  3. Check the cap
    ps had a guy come into a parts store looking for " a new hole " since his pal said he had a dead one... Don't do that
  4. old beet
    old beet
    Runs and starts rite up, #4 has no spark..........Beet
  5. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I'd vote cracked cap. Maybe even a single worn distributor cam lobe.
  6. The Shocker
    The Shocker
    Had a 350 Chevy once that wouldnt fire on #3 (i pulled it from a blazer in a wrecking yard).I ran a compression test and that cylinder had 20 lbs of compression versus 120 in the others.I drove it moderatley for a few thousand miles and finally decided to rebuild it.When i pulled the heads i found that the exhaust valve on #3 was cracked all the way to the stem and had a V shape from it folding up from the crack .I would run a compression test and see what #'s you have all around the board and go from there ...
  7. junkyardjeff
    junkyardjeff
    Does it have a points or duraspark ignition system?,I had a duraspark distributor not shoot spark to one cylinder and it was in the distributor. I dont know exactly what was wrong as I had another distributor and just put it in.
  8. old beet
    old beet
  9. junkyardjeff
    junkyardjeff
    If replacing the cap does not fix it there is a part that I dont know what its callled that is under the rotor that might be the cause,if the pick up coil is not working it would not fire at all so I would suspect that part first.
  10. moses
    moses
    beet what color box is it i might have one color is where the wires go in...jeffrey
  11. 61 chevy
    61 chevy
    got to be a bad wire or plug or cap, for no spark :D
  12. 49ratfink
    49ratfink
    if I were looking for "a new hole" I wouldn't be going to the parts store:cool:
  13. fordrat31
    fordrat31
    from Palmer, MA
    Check for white lines in the underside of the cap. That would indicate a crack.
  14. old beet
    old beet
    Installed a new cap. Compression 100#+. Still not fireing #4......Beet
  15. The Shocker
    The Shocker
    If it wont spark on just that cylinder but has compression ,you may have a bad or fouled plug.If its not the plug then its gotta be a bad cap ,if its just one not firing ...
  16. chopped 35
    chopped 35
    from australia
    check that number 4 lead with a multimeter or try another plug lead on that dead cylinder...........:cool::cool::cool:
  17. old beet
    old beet
    I put a new plug on #4 wire and started engine, moved it to ground to see if it was fireing, ZAP, shocked the shit out of me. Maybe check compression again! Thanks all...Beet
  18. choped41
    choped41
    vacuum leak intake gasket #4
  19. moses
    moses
    well whatn did ya find out burnt valve ? intake leak? jeffrey
