Projects on the bandwagon Heyitsnate's 36 5w build
Discussion in 'Traditional Hot Rods' started by heyitsnate, Nov 7, 2011.
  1. heyitsnate
    heyitsnate
    from tacoma,wa
    ]Been a while since an update... worked on the passenger side cowl patch panel. I made a seperate thread about these cowl patches here's the results.
    Still a couple of spots to fine tune by the a-pillar.
    There was a funky lip on my firewall that was bugging me so i made another patch and put it in.
  2. heyitsnate
    heyitsnate
    from tacoma,wa
  3. heyitsnate
    heyitsnate
    from tacoma,wa
    Some fun pics. Im really bummed on the post. First time using my phone to post. I dont like it.
  4. brady1929
    brady1929
  5. heyitsnate
    heyitsnate
    from tacoma,wa
    ..more to come...
  6. heyitsnate
    heyitsnate
    from tacoma,wa
    Started bolting the front clip together to check my seams on the cowl patch panels. Also made plexi templates of the subrails,cut them out then made them in steel and test fit them on goodgarbs frame. My plan is to build the subrails on another frame (mines twisted in the back)and with the front fenders and running boards attached to it (new frame) i can cut the floors and rockers from the braced body and lower it on and have a good reference to attach it. (From the b-pillars back im leaving old subs and floors intact)
    That probably made no sense.
  7. heyitsnate
    heyitsnate
    from tacoma,wa
  8. heyitsnate
    heyitsnate
    from tacoma,wa
  9. Nads
    Nads
    from Hypocrisy
    Fuck me dude, that plastic idea is killer, mad genius like.
  10. carbuilder
    carbuilder
    Looking good just curious where is your thread on the cowl patch panel.
  11. heyitsnate
    heyitsnate
    from tacoma,wa
  12. swissmike
    swissmike
    I applaude the fact that you fall back on "Science and Mechanics" when the going gets tough. There is entirely too little science and mechanics in todays society....
  13. junk yard kid
    junk yard kid
    that idea with the clear plastic, i love it.
  14. heyitsnate
    heyitsnate
    from tacoma,wa
    Haha mike...research research!!
    The plexi makes it real easy to mark mounting holes, measurements,etc...
    Thanks for the comments guys!
    reagen likes this.
  15. heyitsnate
    heyitsnate
    from tacoma,wa
    Not too much this week. Cleaned the shop a lot, worked on some of my tools. My flathead lives on the floor, while we have a ton of these "universal" engine stands so i made some flatty friendly adjustments. :)
  16. Nads
    Nads
    from Hypocrisy
    Nice old man rocking chair for when you get tarred.
  17. SteadyT
    SteadyT
    Bad ass car, and skills. Greetings from over the Narrows bridge.
  18. Good to meet you Nate...hope those panels will work out! Your car is awesome!
  19. blue collar guy
    blue collar guy
    Whats up Nate. Its cool to see you working on a 36. We have a die for our pulmax to do the lower door and cowl repair pannels. Let me know if i can help you out. Scott
  20. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Nice work Nate, really looks good. Gary
  21. heyitsnate
    heyitsnate
    from tacoma,wa
    You too! Thanks man!
  22. heyitsnate
    heyitsnate
    from tacoma,wa
    Whoa! Whats up scott!?! I will definately give you a call...good to hear from you, i miss seeing you around..-Nate
    Gary-thanks!
  23. heyitsnate
    heyitsnate
    from tacoma,wa
    I got a nice straight frame and i had some x member templates, so i got the ball rolling on those.
  24. heyitsnate
    heyitsnate
    from tacoma,wa
    I also located the perfect set of heads for the 48 flathead im using. The block has a 4" crank,clay smith 5t cam, .60 over, relieved with adj. Lifters.
  25. slammed
    slammed
    You lived in SF back when you joined the HAMB. You built a cool chevy truck/cab. Your latest is some great metal work and ideas.
  26. heyitsnate
    heyitsnate
    from tacoma,wa
    Thanks! This project is alive and well, i've been working on it a lot. Updates soon. Just want to keep it interesting...
  27. Look'n good...I like that plate you made for an unsplit wishbone. Great idea.
  28. heyitsnate
    heyitsnate
    from tacoma,wa
    Making all the x member brackets
  29. heyitsnate
    heyitsnate
    from tacoma,wa
    This is where stuff got tricky. I asked titus how he did his roadster subrails and he helped out a bunch. I basically did the same thing with some tweaks. I made the top pieces, bolted them to the frame, then bent some 1/2" tubing to follow the curve and have the bead inside the door straight across the opening as opposed to following the frame. Then i notched the top subrail and tacked the tubing in the recess i cut.once that was done i traced the subrail sides i cut earlier onto the side of the tubing and cut along the line and also the backside of the subrail..WHEW! Finally i welded the sides on. Not really a stock replica, more like a nod to the og design.
    Still have to make some caps for the ends of the beads on the lathe and misc little things but its getting closer. lve been splitting my time between suspension stuff, working on the motor and trans, and metalwork .im just a few steps from a full roller with drivetrain.
  30. heyitsnate
    heyitsnate
    from tacoma,wa
