Projects on the bandwagon Heyitsnate's 36 5w build
Discussion in 'Traditional Hot Rods' started by heyitsnate, Nov 7, 2011.
  1. heyitsnate
    heyitsnate
    As promised. I have done a lot more than this, but lets start with the dash. I cut a strip from the oem dash and found a good depth and height and stuck them together, then made the ends.pretty straightforward. IMG_20180923_224938.jpeg IMG_20180923_225250.jpeg IMG_20181016_161940.jpeg IMG_20181017_132401.jpeg 20181016_194106.jpeg 20181017_115100.jpeg
    Sent from my SM-N950U using The H.A.M.B. mobile app
  2. That Lincoln dash was really done neatly; looking forward to more.
    heyitsnate likes this.
  3. heyitsnate
    heyitsnate
    You may notice i have a window regulator ,but the speedo covers it. This presented a problem. I did'nt want an ashtray so i made a lincoln knob from some scrap that was surprisingly close in shape that turns in a bolt i made into a bushing. Next i bought a weedwacker for 5.00 from a tweaker and used it's flexible steel driveshaft to link the knob to the backside of the regulator. I extended the worm gear shaft the coupler could bolt to it. There is so much more to it than this, so just know- it took a massive amount of time to do this.im sure more talented hambers would have knocked it out quick but not me lol. Add to that, i really underestimated the work involved with the windshield frame and windshield to body hinges , and lining up the regulator etc. IMG_20180924_001212.jpeg IMG_20180923_224823.jpeg IMG_20180925_221625.jpeg IMG_20180926_210309.jpeg IMG_20180926_210434.jpeg IMG_20181008_011113.jpeg 20181001_115431.jpeg
    kidcampbell71, lowcoe, 51box and 5 others like this.
  4. heyitsnate
    heyitsnate
    We now enter into the "i cant afford this if i screw this up " phase. The speedo. My speedo was nice but had a lot of chipped out paint, some rust and the odometer wheels were f*#$ed. My friend pat found me another movement in much better condition. At 0 miles even. Same wheels, but the housing was smashed.
    Gut check 1- opening the speedo.
    2. Removing the speedo needle. Theres a trick to this, get it wrong and its pure hell. I somehow pulled it off.
    3.swapping the wheels.terrifying terror.
    While i was in there i cleaned everything, repainted the letters, and used Griots garage plastic polish. I really like the stuff. Im not sponsored or anything but griots is super active in our local hotrodding community and i do like to show support ,but really the stuff just works well. Now the movement is back together, and the bezel is getting chromed. The perimeter gauges are beat from rust so im currently figuring out what i will replace the movements with
    20181003_215341.jpeg IMG_20181008_010853.jpeg IMG_20181008_010954.jpeg IMG_20181008_204707.jpeg
  5. heyitsnate
    heyitsnate
    I've been tackling the rear window roll down as well. Nothing spectacular, i pretty much just copied what @Enbloc did .his 3w thread is pretty rad. 20181016_113831.jpeg 20181019_094450.jpeg 20181019_094503.jpeg
  6. Aaron D.
    Aaron D.
    Nice job on the speedo Nate.
  7. Do it Over
    Do it Over
    from NYC, NY
    Great work Nat. I've been searching hard to find pics of this area as mine is bust rusted. Really great work here. Glad I found this. Hope you'll be making the whole thing. Looking forward to more pics.
  8. heyitsnate
    heyitsnate
    Thank you, hamber Enbloc has a writeup on this as well. Common problem with these cars. If i did another one today though i would use a 2 arm regulator .the window will roll more smoothly, especially if you are using universal type window channel felts.
    RICH B likes this.
  9. I was wondering a bit about how the single arm regulator would carry the window level; there is so little square edge to that window to keep it from tilting. I had to adjust the arms on my stock regulator so the window went up and down straight.
  10. heyitsnate
    heyitsnate
    Always better with 2 i think but the single does work . Some earlier fords had singles, they work.i am optimistic. I'll see how it goes, its just 1 panel to change and i kept the forms
    RICH B likes this.
  11. Just checking in on the build. Sure glad you are back on this. Keep the updates coming.
  12. heyitsnate
    heyitsnate
    Great news. The front clip went on as good as you couuld hope for .this is all just static. I didnt adjust the hoodrods, fender braces, or anything. I have never seen my car all together as a full roller for as long as i have had it. It was a GREAT day. IMG_20181231_005246.jpeg IMG_20181231_005359.jpeg 20181230_191259.jpeg IMG_20181230_205347_883.jpeg IMG_20181231_134522_575.jpeg IMG_20181230_193241_718.jpeg
  13. Just keep pushing Nate. I know it's a long road. Nobody knows more than I do. But it looks like you are making good progress. hammer down!
  14. Congrats, man; this is the big step that makes it all worth while. Those gaps around the fenders and grille can be the most problematic; and yours look pretty damn good right out of the box!
  15. heyitsnate
    heyitsnate
    I agree. I have had this and 2 other combinations of front clips, and front fenders,all with crazy gaps but this time it went together 100× better and faster. The front fenders are done done done with metalwork! Woohoo!
    51box, curbspeed, RICH B and 2 others like this.
  16. neilswheels
    neilswheels
    from England
  17. WOW!!!
    35/36 fords rule
    Great work
    Outback likes this.
  18. heyitsnate
    heyitsnate
    Nope, just 36 rules, but thanks!!!
    Outback and anthony myrick like this.
  19. I do like the 36 grill better
    Still would prefer a 35/36 over a 32 (gasp)
    brigrat and Outback like this.
  20. Bandit Billy
    Bandit Billy
    Tony, tony, men sleep with the fishes 'round here for less.
  21. Nate that really looks great! I still have a piece of the hood stainless trim for that nose you bought from me. Pm me your address and I will ship it to you.
    Sent from my SM-S327VL using The H.A.M.B. mobile app
  22. did I see this for sale ? say it isn't so... dig the Lincoln dash and were you were going with it... @heyitsnate
  23. heyitsnate
    heyitsnate
    Not yet. But i'm selling it. I have bigger dreams than this
  24. Nads
    Nads
    from Hypocrisy
  25. Just checking in on any updates on this build.
  26. heyitsnate
    heyitsnate
    It’s a wrap. Car was sold , hopefully it gets what it needs.
  27. Well, What did you end up buying to replace this longtime project. I hope it was good
  28. Any idea if the buyer would continue with the same theme?
  29. vanherrb
    vanherrb
    bump
