Projects on the bandwagon Heyitsnate's 36 5w build
Discussion in 'Traditional Hot Rods' started by heyitsnate, Nov 7, 2011.
  1. Hey Nate. Cool you´re back and nice job on the skirts.Thought you had left us for facebook.
  2. heyitsnate
    heyitsnate
    Thanks kenneth. I needed an extended break. Im preparing for a pretty huge push soon.
  3. F-head
    F-head
    looks great I'd say Marshall was a pretty cool guy but his head is already big enough
    nice work
    B
  4. Aaron D.
    Aaron D.
    Just read the whole thread Nate, great metal work man. You have come a long way from where you started. Keep banging that car into shape.
    Aaron
  5. heyitsnate
    heyitsnate
    Thank you! i made some paper templates,more trunk fitting, and i have decided to follow through on re-doing the subrails. I'm 75 percent sure i can build the entire floor and subrail assembly outside of the car. Then pull the body, set up the chassis, install the floors then plop the body back on and re-shim maybe not in that order but something like that.
  6. bengeltiger
    bengeltiger
    Glad to see you back. Been following since the start. Nice work on your skirts!
  7. heyitsnate
    heyitsnate
    I wrapped up the skirts at least until its time to make brackets, then i took a second run at making the kickup sections of the trunk floor that spot weld to the wheelwells. Going to trim and tune it,then attack the other side and center section of the floor.
  8. heyitsnate
    heyitsnate
    This piece was a brain bender!!!
  9. You are on a different planet. We are not worthy....
  10. heyitsnate
    heyitsnate
    Oh quit it haha i dont know about that. I made the other side. It was hard. Then i static fit it,measured some crap and rolled out the front half of the trunk. Getting closer!
    kidcampbell71 likes this.
  11. heyitsnate
    heyitsnate
    Worked on the trunk riser and scribed all my cut lines, going to make a new rear trunk panel and riser.
    36 ROKIT, bct and lowcoe like this.
  12. heyitsnate
    heyitsnate
    Inching along. I remade the very back panel but forgot about those trunk supports i made when i rolled the beads, so i'll just have to tweak them a bit.
    36 ROKIT and kidcampbell71 like this.
  13. heyitsnate
    heyitsnate
    I started building the floors past the trunk riser. Its a tough spot because of the cutouts. I started by making the pieces that go from the top of the arch to the flat of the frame
    36 ROKIT likes this.
  14. Very nice pieces for your jig-saw puzzle; look forward to the overview. Keep plugging away at it!
  15. heyitsnate
    heyitsnate
    Thanks! Ive been trying to buy a part that i need, and make a part that i need each week. It will start to get more interesting soon, for now i struggled with the floor notches today, made a bunch of scrap, and finally got a pair made that fit the riser. I still need to brake and trim the flanges.After this i should be able to knock out the floor up to the back of the seat, then its gonna get crazy.
  16. heyitsnate
    heyitsnate
    I took the pieces i made back to my shop. My car is hard to crawl around in so i borrowed my shopmates 35 frame to lay out the trunk and temporarily screw it together
  17. YJ4000
    YJ4000
    Looks great!! It's awesome to see how much you are getting done.
    Ryan.
    heyitsnate likes this.
  18. Caddy-O
    Caddy-O
    Very nice work....I like it a lot.
  19. heyitsnate
    heyitsnate
    Last push before the new year...doesnt look like progress, but its almost all welded up .happy to be to the flat of the frame now!
  20. YJ4000
    YJ4000
    Nice! Happy New Year.
    Ryan.
  21. heyitsnate
    heyitsnate
    Lots happened since the last update. Pulled the body, and almost have all the floors done, subrails are done.started restoring the seat, modified the tracks for strength and mounting on a flat floor, set up my roller, pedals,and steering.
  22. heyitsnate
    heyitsnate
    Pic heavy
    kidcampbell71 and bct like this.
  23. heyitsnate
    heyitsnate
    More
    kidcampbell71, bct, RICH B and 2 others like this.
  24. Yowza; skill heavy too! Great progress!
  25. tevintage
    tevintage
    Hi Nate:
    Great to see your progress. Keep on plugging away. Thanks for the update! TEB
  26. heyitsnate
    heyitsnate
    Thanks guys! I painted the seat tracks and hardware ,and made a track release mechanism .did not want to wait for an original.now that its done and works well, i can make it look nice and fine tune the hardware.
  27. 51box
    51box
    from MA
    Excellent job, that is a huge undertaking.
  28. Great to have you back nate! Keep after it!
  29. heyitsnate
    heyitsnate
    Im no woodworker but i think i did all right bringing this seat back from the dead.
  30. toreadorxlt
    toreadorxlt
    from Nashua, NH
    been watching on the instagram... your meme game is on point lately too.
