Hot Rods Oldsmobile Rocket engine identification
Discussion in 'The Hokey Ass Message Board' started by calislabi, Jun 30, 2020.
  1. calislabi
    calislabi
    Hi
    I have an early oldsmobile rocket engine. I'm trying to find out what kind of rocker engine I have
    ( year, cu. inch..........) can somebody help me? Please see picture with the engine number.
    Thanks for your answers
    Patrick
  2. belair
    belair
    55 heads had an 8 cast on them, 56 had a 10. That's all I know. Measure the bore and stroke-that will tell you for sure. @Paul will know, I bet.
  3. Black Panther
    Black Panther
    from SoCal
    A 555641 casting number block is a 303, made from 1949 till most likely 1953..most places say 1949-?
  4. Paul
    Paul
    Editor
    What is the stamped number on the deck surface outer edge between cylinders 5 and 7?
  5. Rckt98
    Rckt98
    There will be a serial number stamped into the block on the side. A small flat area still visible when the head is on.
    I have a list of those codes at home if you can give us the number and no one beats me too it.
  6. Rckt98
    Rckt98
    Paul beat me to it.
