Technical oldsmobile j2 oil pan?
Discussion in 'The Hokey Ass Message Board' started by subneil56, Feb 4, 2017.
  1. subneil56
    subneil56
    from bristol vt
    starting to gather parts for the build 1957 j2 371 , what oil pans are interchangeable if any?
  2. Paul
    Paul
    Editor
    all '49-'58 will fit but must use end gaskets year specific to pan, typical pan gasket sets come with both styles.
    '59 up are a quarter inch longer and will not work.
  3. BJR
    BJR
    The real J2 pan had what looked like an oil filter can welded to the side of the pan to add an extra quart of oil.
    302GMC likes this.
  4. Paul
    Paul
    Editor
    High capacity pans were available from '57 up, not only on the J2.
  5. Fordors
    Fordors
    I'll chalk this up as one more thing I've learned on the HAMB, never knew that before.
    senginc likes this.
  6. junkyardjeff
    junkyardjeff
    I have seen the extra capacity oil pan on a 62 2 bbl 394.
    senginc likes this.
  7. subneil56
    subneil56
    from bristol vt
    I didnt give enough information i have the oil pan with the extra quart capacity ,i was thinking about 303,324or are they different ,and if so what year ?the plan was to get a way from the quart sticking out the side.
  8. mgtstumpy
    mgtstumpy
    senginc likes this.
  9. Neil, any updates on the coupe?
  10. junkyardjeff
    junkyardjeff
    If you do not want the extra quart pan then find a 57 or 58 regular pan.
  11. The 303/324 pans are a bit shallower ( about 1" ) than the 371's. I found this out after spending $225.00 to have my oil pan chrome plated and the baffle in the pan ends up hitting the crank. As for the "tin can" , on one pan I cut it off and welded the hole up and on another ( the one I ended up using ) I just shortened the can enough to clear the header.
