Technical Oldsmobile crank pilot bushing struggle
Discussion in 'Traditional Hot Rods' started by spacecowboy81, Oct 6, 2019.
  1. spacecowboy81
    spacecowboy81
    I am mating a '57 371 Olds to a '55 slant pan hydramatic transmission. This should be easy but I've had to figure things out because the back of my 371 crank didn't have a bushing on it and the factory manual for 1957 of course only discusses the later transmission not the hydro.
    Now I know I need a pilot bushing and the pilot bushing is held in place by a steel retainer. I looked back at my '49 engine and see the same setup. Any one know where I can get this steel retainer?? Or how I can get the one off my '49 crank? I used PB blaster and a slide hammer to no avail. Heres a pic of the back of the crank, the retainer, and the bronze bushing on my '49 engine: 20191002_175133.jpg
  2. studebakerjoe
    studebakerjoe
    Did you try filling the hole with grease then putting a tight fitting round rod into the hole and hammering it into the grease? Basically hydraulically pressing it out.
  3. Budget36
    Budget36
    I've packed the hole with toilet paper and done the same...takes about 1/2 a roll I recall
    loudbang and j-jock like this.
  4. flamedabone
    flamedabone
    Some guys use bread, but I have never tried it. I use the old fashioned stuff it full of grease and drive a tight fitting socket in it technique.
    -Abone.
  5. bonneville bones
    bonneville bones
    Slide hammer with a hook on the end
    bobss396, loudbang and CGkidd like this.
  6. CGkidd
    CGkidd
    I've had to do that to get the steel shield off before.
    Sent from my E6910 using The H.A.M.B. mobile app
  7. Peanut butter works, and is not as difficult to clean up. If you hit your thumb, it doesn't taste as bad.
    Bob
  8. studebakerjoe
    studebakerjoe
    J-jock between the bread and peanut butter you could make lunch while forcing out the bushing
  9. bonneville bones
    bonneville bones
    Mmmmmmm
  10. Just be aware of the potential for a balance issue with this combination...
    loudbang and Paul like this.
  11. Charlie Jones
    Charlie Jones
    from Apopka FL.
    I have an extra bushing and a retainer hanging around somewhere .
    PM me .
  12. s55mercury66
    s55mercury66
    from SW Wyoming
    One can also run a tap into the bushing and it will bottom out on the crank while forcing the bushing out. Use the smallest tap possible, it doesn't need to cut usable threads.
  13. ekimneirbo
    ekimneirbo
    I haven't fooled with any old Olds engines, but I didn't think an automatic ever used a pilot bearing. Is this some kind of oddball thing that Olds did? I do know that long long ago you could get "straight stick" olds vehicles, but I never saw an automatic with a pilot bearing.
  14. CGkidd
    CGkidd
    4 speed hydro used pilot bushing to support input shaft inside the Taurus.
  15. just Mike
    just Mike
    Bread works amazing, even on the roller bearing style. One slice does it and no greasy mess to clean up!
  16. 302GMC
    302GMC
    from Idaho
    All single & dual range hydros use a pilot bearing or bushing … don't remember on '56 up.
  17. I do the same as ms55mercury66 said,I run a tap into the bush,then use a bolt of the same size and as you tighten the bolt,the bush just slides out.
  18. J. A. Miller
    J. A. Miller
    from Central NY
    That retainer looks like a core plug with a hole in it. If that's true, can't you do a little measuring and modify one?
  19. Paul
    Paul
    Editor
    Take a close look at the '57 crankshaft, it likely needs machining to accept the pilot bushing, if it does, have the shop also give the rotating assembly a neutral balance to work with the early transmission.
    If by chance the crankshaft will take the bushing as is, you will still need to address the balance issue, take the balancer, crankshaft and torus cover in to have them all balanced together.
    Either way the balance issue will need to be addressed.
    warbird1 likes this.
  20. wuga
    wuga
    Because Olds mostly came with automatics, they felt machining the pilot hole was a waste of resources. I take it you are going to a standard transmission so index the hole to verify it is centered and then machine down your pilot bearing to fit using one of the methods mentioned above. That is what I had to do.
    Warren
  21. poprivit
    poprivit
    from Hagerstown
  22. poprivit
    poprivit
    from Hagerstown
    I borrowed a pilot bushing puller from Autozone , worked great !
    Blind hole bearing puller
    Works great for this kind of stuff
    The grease and punch thing eitknreally well also
  24. s55mercury66
    s55mercury66
    from SW Wyoming
    We found this out by accident, when as teenagers, we needed a pilot bushing, and had to reuse the one in the old motor. We found that by running the tap in, and bottoming it out against the crankshaft, it just pushed the bushing right on out. This was on a '66 GTO, with the ubiquitous Muncie 4 speed, and since we used the smallest tap we could, it cut some fairly light threads in the bushing. We felt it would retain grease better that way :)
