Projects *oldsboy*_T-sedan build
Discussion in 'Traditional Hot Rods' started by oldsboy, Jan 11, 2011.
  1. oldsboy
    oldsboy
    Timm thanks for the heads up! not a bad idea.... I wasn't sure if I wanted to cut and weld on them but this should be pretty simple.
  2. NortonG
    NortonG
    This build is amazing!
    Great job fella!
  3. Tim
    Tim
    from KCMO
    Yeah I'd be Leary of cut/weld I just got mine hot and bent it. Figured with the way you have it now you wouldnt end up with funny ratios, arc or placement but just a dropped position.
    Another thought would be to change up your pushrod/ linkage length in a way that "all the way up" is lower but then youve theoretically got a shorter throw and the bend in the arm hanging down underneath kinda weird.
    I'd just cut, bend, drill.
  4. oldsboy
    oldsboy
    As mentioned here is an update on the headlight mounts we worked on last weekend. The mount(s) need some finishing which should happen this week. I just got a little excited to bolt the headlights on, step back, and take a look as they have been in my closet for quite awhile now. So its nice to finally get them out in the daylight.
    Brackets
    Welded but unfinished...
    Shadow Creek likes this.
  5. oldsboy
    oldsboy
    Finished up the metal work on the headlight bar tonight, nothing like taking advantage of some cool temps in the garage/ shop.
    Feels good to have something to check off the list...
    Shadow Creek and brEad like this.
  6. It doesn't matter how long it takes to get done as long as it comes out bitchin'. And this T sedan is very bitchin'. Great job. I am diggin' this build. I am glad you have a plan and are sticking with it.
  7. Tim
    Tim
    from KCMO
    Awesome man :) looks real slick. Can't wait to see what you come up with next :)
  8. TexasSpeed
    TexasSpeed
    from Texas
    Everything about that T is perfection. I can't wait to see this up and driving.
    No pressure, of course.. I know how that feels. Haha. :D
  9. lowtruck
    lowtruck
    from Omaha
    Let's see that steering hoop. I'm still not completely convinced that I understand what you were telling me the other night. I need pictures.
  10. Tim
    Tim
    from KCMO
  11. oldsboy
    oldsboy
    Over the weekend I managed to finish up the steering assembly.
    I started with making a steering hoop. I was going to attempt to drop a stock arm from speedway, but from a few other posts via the HAMB, I would have lost too much length in the drop to make it work. So, I had no choice but to come up with a custom arm.
    Long story short I went through the calculations supplied from the Bishop-Tardel book which puts me in the "desired" range. So we'll see. I wanted to achieve a parallel relationship as well between the drag link and split wishbones in an effort to avoid bump-steer, thats why the arm seems pretty tall.
    I had a some excellent guidance running the blue wrench...
    I did make an insert plate for the arm as well, just didn't have my camera on hand....nothing like a hole saw and a fresh cup of coffee to kick off the weekend.
    brEad likes this.
  12. oldsboy
    oldsboy
    Steering assembled.
    Last time assembled this season, but the first time the actual motor and trans have been mated in the car. So far a whole lot of issues. I need to shorten the shifter by about 4" though and move it over to the passengers side about 3-4" as well otherwise I'll be shifting through the steering wheel.
    Can anyone provide some tips on this part, if you've done this before. I know at some point in the last 60 years its been done, but I'd like any type of heads up....
  13. chaddilac
    chaddilac
    Very cool!!! Dig the steering setup!!
    What's the strip on the firewall? I assume you added some to move the bottom down?
  14. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    This is turning out incredible!!!! Might be one of my new favorite threads!!!
    Here's one of my all time favorite T Sedan.....come to think of it besides you's it might be my only!
      400.1 KB
  15. oldsboy
    oldsboy
    You're on it! Since I raised the cowl I wanted to use the original firewall so I had to add material to it as well. This summer I was mostly taking advantage of my time by roughing everything in. With the intentions of this winter to clean it all up.
    Its the strategy I have to work with since I have to do my work outside.
  16. chaddilac
    chaddilac
    Oh shoot I forgot your moved the cowl up!!! It does match up way better than stock now that I'm looking at it!! Great job!
  17. Dude your car is coming out awesome! I dig the headlight placement and the under-cowl structure!!! I'm gonna do something similar with my cowl....
    Joe
  18. NortonG
    NortonG
    Super bitchin!
    As for the shifter, get a seat in there and get comfortable with the steering wheel.
    Then heat and bend the shifter in a couple spots to make it work with your seating position.
    ....and to make it look cool.
  19. oldsboy
    oldsboy
  20. oldsboy
    oldsboy
    Lightening holes!!! Just not so fun without a drill press....
    SO I managed to get all of the steering components finish welded and have begun the clean up, but I figured why not punch a few more holes first.
    brEad likes this.
  21. TexasSpeed
    TexasSpeed
    from Texas
    Best looking T sedan in a long time. Seriously.
  22. Tim
    Tim
    from KCMO
    Meh' it's alright.
    Haha someone's gotta make sure his head fits threw doors ;)
    brEad likes this.
  23. oldsboy
    oldsboy
    Hahah, Thanks Timm! I now know I can rely on you to keep me grounded.
    40Mike likes this.
  24. This thread/build is giving me big inspiration. Nice work on the car Oldsboy...
  25. Malcolm
    Malcolm
    from Nebraska
    Finally caught up on your progress. Looking VERY good, Ryan -- nice work!!!
    Malcolm
  26. oldsboy
    oldsboy
    Well it happened, the machinist called today and I have a case of "lifter valley crack" and from what I've read and what he has told me it doesn't sound too good. He mentioned its in an extremely thick area of material and isn't 100% confident of any fix. However everything else is good to go, the crank and rods how just need a home.
    I'll update when I get the project back on track, I've got a lead on a 40 military flathead which I'll be checking out next weekend.
    Nothing like flathead hunting on Thanksgiving.
    If anyone has any info on '40 flatheads here's my other thread...
    http://www.jalopyjournal.com/forum/showthread.php?p=8354849#post8354849
  27. Tim
    Tim
    from KCMO
    Well shit. I'll start looking around
  28. ThirdGen
    ThirdGen
    from Wales, ME
    Haven't checked this build out in some time, things are progressing nicely. Damn good looking T!
  29. RichG
    RichG
    Glad to see you're still motivated on this, bummer about the engine though. Good luck hunting down another one.
  30. oldsboy
    oldsboy
    It's been a long few days... but I managed to snap some pictures of the crack in the block. Seems to be in a very odd location. There were also a few other standard cracks in the head studs; pretty typical but I thought I'd include them as well.
    But the good news is I've already found a replacement and at the machinist as of this morning. It's not a 59ab as I couldn't find a decent looking replacement. So I opted for an 8ba with the metal truck bellhousing. I should have enough room in front of the engine so I shouldn't have any clearance issues and if so then I'll just run the early distributor with early pumps. We'll see. Right now I'm just waiting to hear if the block is good before I make any real plans...
    I'll add photos of the new block as soon as I can.
