Hot Rods Olds Rocker question? 303 vs 324
Discussion in 'The Hokey Ass Message Board' started by bobbleed, May 6, 2021.
  1. bobbleed
    bobbleed
    from Awesome
    Ok so I have an early 303 with stock heads and have complete rocker shaft assemblies and stands from a 324. I am planning on using the 324 pushrods. is this right? will the early 303 lifters work with the larger diameter 324 pushrods?
    or do i use the smaller 303 pushrods, which are shorter.....?
    thanks!
  2. mgtstumpy
    mgtstumpy
    Could I suggest Tony @GOATROPER02, Olds Rockets are his forte
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    @Paul is an Olds expert
    Tim likes this.
  4. Paul
    Paul
    Editor
    The ball end of the push rod needs to be the same radius as the receiving cup on lifter and rocker.
    1940Willys likes this.
  5. bobbleed
    bobbleed
    from Awesome
    Thanks Paul, do you know which pushrods I need length wise? I’m thinking I need the ones from the 324.
    I’ve read a bunch about changing from the early 1.5 rockers to the late 1.8 rockers but haven’t found any info on the rockers and lifters.
    I think I might have to use the late lifters.
    Thanks
  6. Paul
    Paul
    Editor
    Hi Bob,
    length needs to be checked,
    use new or regrind cam, new lifters, clean up rockers and check length and order push rods to fit.
    might as well throw in a new timing set while you have it open.
  7. bobbleed
    bobbleed
    from Awesome
    Im trying to get an old motor running. It has some worn rockers, I dont have any early rockers but have a complete later set. Ive read about people doing this swap, just trying to figure out what others have done when they did this swap
