olds motor
Discussion in 'The Hokey Ass Message Board' started by 79shovelhead, Feb 15, 2011.
  1. GOATROPER02
    GOATROPER02
    from OHIO
    Which 5 sp?
    I do new ones with the GM bolt pattern
    Tony
  2. hudson hot rod
    hudson hot rod
    Still going over the options as to which t5 would be the best, there are a ton of them out there! Would like a v8 trans with cable linkage. Also do I need one with a longer input shaft?
  3. GOATROPER02
    GOATROPER02
    from OHIO
    I would too, but the owner wanted those and he pays the bills:D
    I would have liked dimpled covers painted with lettering,
    I dynoed it with these chrome ones and it really was blinding
    Tony
  4. GOATROPER02
    GOATROPER02
    from OHIO
    No, standard Gm input length as in same as a muncie
    Why cable?
  5. hudson hot rod
    hudson hot rod
    Easier than putting linkage in a small car and can hide it better with a car that has no hood. Never worked with one, maybe not how I imagine it.
  6. But the idea is to pass it off as a "Hot Rod Lincoln" :D:D
    I'm with you but to each his own I guess.
    Olds powered rods. I know there are more out there lets get a look see.
  7. GOATROPER02
    GOATROPER02
    from OHIO
    You mean clutch cable instead of linkage,:eek:I was thinking you ment shift cable and I was lost
    Go Hydralic...,easy and simple
    Tony
  8. gonzo
    gonzo
    Using the Olds stick set up wouln't be the worst thing to ever happen. Get a good set of highway gears for the rear end and you'll be fine. If you decide to go the T5 route just stack the adapters. Olds to early Ford and then early Ford to Chevy. You'll have to find a pilot bushing (Wilcap may have them) or have one made, no biggee, then your done. It will take a lot of driving to recoupe the extra money to put a T5 in, unless I drive like a granny my car still gets piss poor mileage.
  9. Gonzo
    I like the wide 5s. How's the 60 horse rear holdin up behind the little olds?
  10. gonzo
    gonzo
    I'm actually running a truck center section with a set of 40 ford bells and so far so good... knock wood. The tires are skinny and I keep the pressure pretty high so they mostly just spin if I get a little too ambitious with the pedal.
  11. Now I never would have thought of running a truck center.
    I had a buddy when I was a kid that cut extra keyways into the axles on the hub end to fix that problem but he was forever breaking the center.
    He was a late model guy always ran 394s in a '38 coupe.
  12. 79shovelhead
    79shovelhead
  13. FC49
    FC49
    Another Olds / Ford combo seen at Detroit last weekend.
    Frank C.
  14. gonzo
    gonzo
    Pretty simple way to do it and with the over drive tranny the truck gears aren't too bad as long as they're no higher than 4-11. If you end up with the super granny gears its a good idea to swap them out.
  15. Yea I guess unless you have your rocket built to really rev or you have really tall tires you wouldn't want to go much lower than a 4.11:1 gear. Most rockets unless just built to the hilt don't turn that many revs.
    I'll have to keep the truck center in my log of remedies for future use.
    frank that coupe has a lot going for it. I wish I had a model 40 to shove my big old pig into.
  16. 79shovelhead
    79shovelhead
  17. There must be more Rocket powered cars on the HAMB there are sure a lot of Rocketeers here I know they are not just looking at their motors and grinning.
  18. FC49
    FC49
    I have no photos of the Olds-powered '53 Ford Vic hardtop I had long, long ago. It was black with a white roof. Body was 100% stock. Interior was replaced with '54 Merc Monterey which was much more plush than the Ford seats.
    Engine was a 324 with 10:1 forged pistons, Isky solid-lifter cam, single Carter 4-bbl, Edelbrock finned covers for rocker clearance, dual-point conversion in the stock Olds distributor. Aluminum flywheel, borg and beck clutch, into a side-shift LaSalle 3 speed with Hurst shifter. Hedman Hedders thru a pair of glass-paks.
    Dropped tie-rod and re-located starter kit to make it all fit. Radiator was stock Ford with converted to single inlet/outlet. It was barely adequate.
    Fun car. It ran great, sounded even better. The solid-lifter clatter with the glass-pack tone was better than viagra. Handling wasn't too good with that added front end weight but not much worse than stock Fords.
    Had to sell it when life intervened with fun. Of all the cars that "got away" I miss that one the most. It left me with a big soft spot for the Rockets. Maybe it's better not to have a picture.
    Frank C.
  19. FC49
    FC49
  20. gonzo
    gonzo
    How about pics of my buddy's Olds powered coupe on its way to Bonneville a couple years ago, would that help scratch the itch?
  21. Rocket-Boy
    Rocket-Boy
    my algon injected 324
  22. Never2low
    Never2low
  23. S.F.
    S.F.
    Why does an olds rocket have lincoln valve covers....wow....seriously?
  24. 79shovelhead
    79shovelhead
    that coupe looks great
  25. 79shovelhead
    79shovelhead
  26. lowkroozer
    lowkroozer
    goatropero2,sounds like you should make kits for Olds and 5 speeds. Oh yeah,hi
  27. von Dyck
    von Dyck
    Remember that the 303, 324, 371, 394 engines have the unique (to GM built V-8s) firing order 1-8-7-3-6-5-4-2. That alone makes us a special breed.
  28. GOATROPER02
    GOATROPER02
    from OHIO
    I already do
    Nice talkin to you you a few wks back,
    Tony
  29. GOATROPER02
    GOATROPER02
    from OHIO
    I expressed this to my customer that its not what I would do.....but in the end its his car
    I wanted a pair of blue dimpled covers with some type olds/rocket lettering
    Others have said as you and I will bring this to him again
    Tony
  30. FC49
    FC49
    I'd leave them on. A lot of work went into making them fit. They had to be mounted upside down, the Lincoln script cut out and flipped and then welded in again. Besides, I was floored when I saw it was an Olds, not a Lincoln, and I wouldn't have been that knocked out otherwise. Yes, the engine is a showpiece and truly gorgeous, but so are a lot of the other cars that were there. This makes it unique.
    Although I do love the J2 covers. If it was my car, I'd be alternating them depending on my mood.
    Frank C.
