Olds ID & mounting Help
Discussion in 'The Hokey Ass Message Board' started by ZZ-IRON, Jan 20, 2012.
  1. ZZ-IRON
    ZZ-IRON
    from Minnesota
    Olds Guys - Need help
    what years did Olds come out with wire wheel covers
    how were they fastened to the rims?
    they do not snap on like normal covers you try that they fall off
    photo snapped at a car show - you can see the steel rim & weight
    Thanks for any help or if you know an alternative way that would help
  2. 302GMC
    302GMC
    from Idaho
    1953, maybe available 1954
    The center cap snaps off, 3 of the lug nuts hold it to the wheel.
    Pontiac, Buick, & Cad used same basket with their own center cap.
  3. ZZ-IRON
    ZZ-IRON
    from Minnesota
    Thanks for the info
    I dug in the box the wire covers were in
    found the round steel mounting piece has large holes the a lug nut would pass through
    so they must of used large flanged lug nuts
    here's photos of the Olds cover there are 3 pieces
    large flanged lug nuts is my guess
    I had these 53 Buick V8 wire wheel covers with a much different mounting system heavy steel mounting dish mount
    the spokes were sandwiched from the top and bottom together
    Olds system is different it has 3 pieces
    the Buick had 4 pieces
    V cap snaps into the spoke retainer that screws in to the blue mounting dish and the cover
    this is one reason i though some parts were missing
  4. GM revisited this in the mid-80s for wire wheel caps (the ones that have one bolt holding them to a center cap underneath), so you should be able to find lugnuts that will work pretty easy - 5x5 pattern cars have 1/2"s that should also work on the Olds unless one side is left hand.
    I have a full set of generic ones, I'll have to check out how they mount now. I grabbed them at the flea market because they look just like the 53-54 factory caps, but the center cover is plain and they have an insert under the wires, I guess to hide if the rims didn't match or something.
