Olds engine compatible? 303 and 324
Discussion in 'The Hokey Ass Message Board' started by Del Clark, Jul 18, 2012.
  1. Del Clark
    Del Clark
    from DeLand,FL
    I bought a 1950 olds club coupe with its original 303 and I want to put a 1956 324 in it... Is it compatible? Mounts? Tranny etc? Thank you
  2. Olds Dad
    Olds Dad
    Like changing a light bulb
  3. Bobert
    Bobert
    If you are using the 303 hydra-matic trans there will likely be some trans throttle pressure linkage and carb throttle linkage mods to do. Not difficult just fiddly. Found this as I have a '55 top end on my 303. Couple more things come to mind. If you are using a heater the hoses will re route no big deal. You need the 324 exhaust manifolds 303 are much smaller. The 324 right side has a funky horizontal outlet which will require exhaust pipe fab.
  4. F&J
    F&J
    Stop before you buy :)
    Olds had 2 different A/T in 56 only.
    The 324 from a standard shift, as well as an A/T 324 that came from the cheapest base model 88 will have the pilot bushing that will fit your 50 trans, no matter if your car is stick or A/T.
    The 56 A/T in the better 88, and 98 will supposedly not have a crankshaft that is drilled for a pilot bushing.
    If the 324 is A/T : Look at the crank, or if it's still in the car, look to see if the shift indicator letters have a P for park. If it has no P you are OK, because it's the older trans.
  5. ZZ-IRON
    ZZ-IRON
    from Minnesota
    I have a 50 Olds 88 club coupe i put a 55 Olds 324 & 55 hydramatic in the 50 Olds and still haven't got my rear mount problem solved
    used a 50 Olds cross member and tried 50 & 55 rear mounts
    on the 55 i have angle problems
    i was looking for a Hollander to check if 50 & 55 cross members a different if so a 55 cross member could be the cure i'm planning a trip to French lake in search of a 55 X
    so far no luck you might have the same problem for a bolt in
    i had a 50 Old hydramatic if i remember the tailshaft was shorter then the later 55 trans
    got the new mounts on ebay there compatible check list said the mounts are different from 50 to 55
    so if you solve your problem let me know and i'll do the same
  6. Olds Dad
    Olds Dad
    sorry...jumped the gun - was thinking engine only, not rear engine (tranny mounts). Don't listen to me, I drink.
  7. Del Clark
    Del Clark
    from DeLand,FL
    Can I use my original hydra matic from 1950?
  8. Dave50
    Dave50
    The mounts are different depending on tranny ebing used the bell has different holes i ran into the same problem but i made a sold mount for now. I think you can just swap sides and drill the bottom hole in the mount and it will work From what i could see but decided quick and easy
  9. GOATROPER02
    GOATROPER02
    from OHIO
    If using 50 hydro a 324 is direct bolt in except for ex manifolds as said...... Also make sure your 56 crank is drilled for a pilot bushing the same as your 50.......2 different cranks in 56....some are some aren't
    Tony
