This bolt in spring will lower your car 3" inches (4" if your remove a few leafs) with no alterations needed to your stock Model A frame or body in a "spring over" application. Based on the 26/27 rear T-Spring dimensions using OEM FoMoCo specifications, this spring is built to Model A rear spring width (2.25′′ inches) to fit in a Model A rear cross member without use of shims or spacers Additionally, this spring works well in 32-34 frames with "spring behind" applications and is also compatible with traditional quick change set ups. Made in the USA of SAE 5160 rolled steel. Available with or without spring shackles and urethane bushings. NOTE: Only available in reverse eye. DIMENSIONS Overall Width: 42.5” inches eye to eye Overall Unsprung Height: 17” inches Spring leaf width 2.25” inches DESCRIPTION
One left in stock until our new order comes in! Get it and avoid the wait! Sent from my iPhone using H.A.M.B.
Back in limited stock (finally) We ordered 80 springs Nov’ 20. Just received 13 of them almost two years later. Stock is limited so get your’s before they are gone
